2006 GT Problems..
Old Apr 5, 2013 | 08:04 PM
Stang-Nator's Avatar
Stang-Nator
Default 2006 GT Problems..
If i accelerate and let off the gas, then hop back on again to accelerate the car will hesitate and the exhaust will pop and knock. Its not extremely loud but its definitely noticeable. Also, if im cruising the car will shift into a high gear, before 2500rpm and when i accelerate in the gear it shifts to, it knocks and the car stutters and shakes.. Any ideas whats wrong? Just started doing it today.
Old Apr 6, 2013 | 04:52 AM
petrock's Avatar
petrock
Automatic or manual? Sounds like an automatic. Sounds like a transmission problem given the unintended shifting issues. Check the tranny fluid level. If you haven’t changed it in the last 60k miles, it is probably due. I’d start there... Good luck...
Old Apr 6, 2013 | 12:42 PM
Stang-Nator
Yes automatic, could the transmission cause the exhaust to pop and hesitate like that?
Old Apr 9, 2013 | 01:42 AM
petrock's Avatar
petrock
I’m not sure. But, in theory, if the tranny isn’t shifting when it should then it would be in the wrong gear resulting in the rpms getting too high or low (depending on if the gear is too high or low) which can cause weird problems.
PullTab
Oct 30, 2015 08:46 AM
kevsgt
Oct 9, 2015 10:12 PM
BeatnikFink
Oct 1, 2015 08:00 PM
BrantleyS550
Sep 14, 2015 04:18 PM
Mustangmalo
Sep 6, 2015 05:22 PM
