fuel psi??
Old Dec 18, 2003 | 12:38 AM
nemethjames1's Avatar
nemethjames1
Default fuel psi??
i have a 89 gt ho convertible, and when i turn the key on the fuel psi is only 5lbs, and when i run a direct hot wire to the pump it puts out around 35, and the book says thats enough to run it, what could it be? besides the relay, inertia switch, fpsi regulator, fuel filter....?
Old Dec 18, 2003 | 09:09 AM
vfast's Avatar
vfast
I ♥ Acer
Default fuel psi??
your getting more current to the pump with a straight wire that's why for the higher pressure....where are you taking the f/p @?......you'll need a new pump if the relay isn't bad
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Sixx
Oct 5, 2015 07:36 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
mrappe
Sep 26, 2015 10:16 AM
