answer maybe??
Old Dec 19, 2003 | 01:53 AM
95Stealth302's Avatar
95Stealth302
Default answer maybe??
Hmm, sounds like a computer problem then. Strange thing about that kind of diagnosis is that I really can't recall any computer sensing device that would have RPMs dependant on clutch placement aside from starting the car.</P>
Ha, I just thought of something. If it jumps and stays there, does it also do it at other times? If so, then it's a vacuum leak. Could still be vacuum leak if it just does it while shifting, and actually I think this is the best bet. Check hoses and EGR stuff with some soapy water spray to see if its leaking or not. Hope that helps.</P>
Old Dec 19, 2003 | 11:22 PM
89muscle's Avatar
89muscle
WHEN YOU PUSH THE CLUTCH IN THE FLYWHEEL SPINS FREELY SO THERE FOR THE FLYWHEEL WILL SPIN BECAUSE OF NO DRAG.
Old Dec 20, 2003 | 10:01 AM
BLKSTANG9879's Avatar
BLKSTANG9879
Are you sure it's your clutch? It sounds like a throttle or a computer problem to me!!
Old Dec 20, 2003 | 12:26 PM
SilverGTV8's Avatar
SilverGTV8
I know Ford had a problem on the 5spd Focus when they came out with the computers. Inadvertanly the automatic computer code iniciated and/or was installed in the car. When you shifted the REVs would climb about 500rpms. made for jerky upshifts.</P>
Lightened flywheels occasionaly do this but not when you are sitting still and they usually drop revs super quick.</P>
I would have the computer checked by a dealership for what program is in it.</P>
vargas
Jun 17, 2017 12:17 PM
guitarman376
Sep 30, 2015 05:54 PM
JayGee
Sep 15, 2015 12:41 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
BrantleyS550
Sep 14, 2015 04:18 PM
