Low coolant sensor/coolant reservoir question
Old Oct 4, 2005 | 02:30 PM
tommy_t's Avatar
tommy_t
Default Low coolant sensor/coolant reservoir question
I have a bad low coolant sensor and when I went to the dealer he said I can't buy the sensor only, I have to buy the whole reservoir with he sensor in it! This is ridiculous!
Anyone know if the sensor is replaceable without changing the reservoir? And if so, where I can get the sensor?
Old Oct 4, 2005 | 02:33 PM
tommy_t's Avatar
tommy_t
Default RE: Low coolant sensor/coolant reservoir question
Forgot to mention I have a 99 GT
Old Oct 4, 2005 | 03:15 PM
kartracer55's Avatar
kartracer55
Why bother? Its just an idiot light.
You should be checking the level of coolant, oil, and brake fluid every 2 weeks or so anyway, and before any long road trips.
Jim
Old Oct 4, 2005 | 11:19 PM
Chopper's Avatar
Chopper
I don't know how the sensor works but if there's any moving parts,like maybe a float,take the reservior off the car and clean it with soap and water.Use a long brush to loosen any dirt that might be hanging the float.Shake the reservior around with the soap and water in it and see if it fixes the problem.If this don't fix anything,try unhooking the wires or using a jumper between the terminals and see if that extinguishes the light.If this doesn't work you can always raise the hood and check personally.Repost and let us know what you find out.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
GimpyHSHS
Sep 18, 2015 12:27 PM
MusicCity615
Sep 12, 2015 07:05 AM
cbird1177711
Sep 3, 2015 08:43 PM
