Camshaft sensor, ect.
Old May 2, 2013 | 06:13 PM
Pepper54's Avatar
Pepper54
Unhappy Camshaft sensor, ect.
My 04 mustang will be the death of me.
A few days ago my check engine light came on. Got it scanned "camshaft sensor position bank one". Cool. Got a new sensor and replaced it. Worked for about a week. Check engine lights back on... Same reading when I got it scanned. Used a Borg Warner sensor, so it strikes me as off that it's already out. I heard to get a high end sensor to replace and that's what I did. I also read elsewhere that it could be the alternator? But my car is holding a charge... Any ideas?
While I'm here, this is also going down: a heavy vibration and light squeaking in my clutch peddle. Downshifting and deceleration makes the peddle go absolutely bat **** crazy. Idled is when the squeezing starts. The squeaking sounds like a belt... However when you barely engage the clutch, the squeaking stops. I thought it was the throw out bearing. Replaced it, put in a whole new clutch kit, the pressure plate looked fine, however it started again two days later. Though maybe I got a bad bearing? Replaced it, and again, two days later the vibrations and god awful squeaks came back. Any ideas??
Thanks in advance
Old May 2, 2013 | 10:41 PM
FrostByte's Avatar
FrostByte
On the camshaft sensor error its probably your alternator going out. Its creating a radio frequency that interferes w/ the PCM.
Old May 8, 2013 | 12:26 PM
bchea's Avatar
bchea
I have the same problem with my 04
Old May 8, 2013 | 08:37 PM
FlamingoGT's Avatar
FlamingoGT
The camshaft sensor error is almost always the alternator.
I would think the squealing could be the throwout bearing also, but as you changed it twice already I don't know.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
NYstang
Sep 30, 2015 09:56 PM
