Lifters making noise?
Old Dec 19, 2003 | 01:40 AM
95Stealth302's Avatar
95Stealth302
Default Lifters making noise?
So if you've ever heard an old bronco or a big old 80s caddy go buy you you'll know what I'm talking about. </P>
RPMs really make no difference, but the noise is especially present say at about 50mph in 5th. When I press on the pedal, I hear a ticking noise, like lifters or something. Just a rapid ticking noise, similar to that of the cars described earlier. Its definately in the internals of the engine, not sure exactly which piece. Any ideas? I really dont know how to describe it better, just a really rapid ticking noise that goes away over 3k revs, or I just can't hear it past then.</P>
Old Dec 19, 2003 | 03:08 AM
hotrodman's Avatar
hotrodman
I ♥ Acer
may be wrist pin try pulling 1 plugl wire off at a time if noise goes away {,with eng.running at idle}problem is on that cylinder.good luck
Old Dec 19, 2003 | 04:45 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
good advice that was what i was going to say.Also you may have worn a cam lobe out.Very rare on a roller block.What engine is this you are referring to?
Old Dec 19, 2003 | 11:32 AM
95Stealth302
My 302, and thanks, I'll check the cylinders, anything else?
<edited><editID>95Stealth302</editID><editDate>37974.3990393519</editDate></edited>
bjdutch2005
Mar 24, 2017 03:38 AM
04stangman
Sep 17, 2015 01:45 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Emblazoned
Sep 3, 2015 10:45 PM
