2000 mustang gt
Old Oct 7, 2005 | 09:28 PM
mastaking's Avatar
mastaking
Default 2000 mustang gt
my 2000 mustang gt the electric fan runs all the time the engine run any idea maybe the relay if so where is it
Old Oct 8, 2005 | 03:07 AM
Chopper's Avatar
Chopper
Default RE: 2000 mustang gt
Accordingn to the Haynes manual the fan can run all the time if the coolant temp.sensor or the Constant Control Relay Module (CCRM).I'd guess the coolant temp.sensor.
Old Oct 9, 2005 | 09:24 PM
mastaking's Avatar
mastaking
where is the ccrm at i dont see any relay or box in the fuse box under the hood or in the car
Old Oct 9, 2005 | 10:55 PM
PipsBlackStang's Avatar
PipsBlackStang
I have the same problem on my 96 GT. I changed out the engine coolant temp sensor ( located on the first intake manifold crossover, next to the stat.) Then I replaced the CCRM( located inside the passenger side fender well, you have to take out the plastic fender well thing to get to it, its a little black box) and that didnt fix it eighter. So I swapped out my PCM(Powertrain Control Module) Sometimes called ECU with my brothers 96 GT PCM and it fixed the problem. I havent purchased a new PCM yet but when I did the swap it fixed the problem and then I put mine back in just to drive it around for awhile. I would do the sensor first since its like 5 bucks then the CCRM and then if nessasery do try a new PCM. That will fix you up and get you running as good as new.
Old Oct 10, 2005 | 06:48 PM
mastaking's Avatar
mastaking
hey guys thank for your help i took the fender wheel cover off and started tapping the relay with a hammer and now it works it even comes on and turns off whilke sitting so ill change it out so it doesnt do it again and thanks for your help
mmbrown
Sep 8, 2015 01:29 AM
01blackgtconv
Aug 14, 2015 04:50 PM
$A_Money$81
Aug 11, 2015 01:30 PM
daytooday
Aug 11, 2015 09:22 AM
01blackgtconv
Aug 10, 2015 01:25 PM
