Differential oil change
Old Nov 15, 2013 | 08:59 PM
rhgore's Avatar
rhgore
Default Differential oil change
I am going to change my differential oil tomorrow in my 89 GT and I was wondering if anyone had any tips. I have a very loud whine in my rear end when I accelerate. The car has 3.73 gears in it. Just wondering what is the easiest way to drain the fluid? Should I remove the cover or just the bolt and use a pump? I was going to replace the current oil with royal purple 75w145. Thanks in advance for any tips.
Old Nov 15, 2013 | 11:57 PM
petrock's Avatar
petrock
Since you have a noise, I would pull the cover so you can get a look at the gears, how they are meshing and make sure there aren’t metal shavings/chunks at the bottom of the diff, and so you can clean the magnet at the bottom of the diff housing. Good luck...
Old Nov 16, 2013 | 01:41 AM
Derf00's Avatar
Derf00
Gentleman's Relish
when did the whine start or, has it always been there? Gear whine is usually caused by something mechanical like wear or pinion angle on the shaft to differential yoke. Like petrock suggested, take a look at the gears and the oil coming out.
Old Nov 16, 2013 | 07:21 AM
rhgore's Avatar
rhgore
Thanks for the info. I just got the car so it has been there since I got it.
Old Nov 16, 2013 | 10:40 AM
uberstang1's Avatar
uberstang1
Chupacabra
If the rears whinning unfortuantly I oil change wont helo you
mtgldr
Feb 3, 2024 09:00 PM
2007StangV6
Jan 28, 2016 06:09 PM
MusicCity615
Sep 12, 2015 07:05 AM
kevsgt
Sep 9, 2015 06:20 AM
