Torque Specs / Chrome Wheels
Old Oct 11, 2005 | 07:39 PM
SteveIdeas's Avatar
SteveIdeas
Default Torque Specs / Chrome Wheels
In another thread here, somebody mentioned that it was possible to crack chrome wheels by overtightening them, so it was good to put them on with a torque wrench.
That's good advice - thanks...
Question: What torque specs should I use when putting my chrome wheels on the car?
Steve
Old Oct 11, 2005 | 07:58 PM
Tim37's Avatar
Tim37
Default RE: Torque Specs / Chrome Wheels
Check with the manufaurer of the wheels. Be sure to re torque them a couple of times they can come loose after 20 or so miles. Personaly i used to work in a tire shop and never cracked a chorme wheel just make sure you have someone that knows how to mount tires and never I MEAN NEVER USE FIX A FLAT!!!!! that stuff will rust out a steel wheel make a aluminum wheel pitted and corroded but the worse thing it will do is get under the chrome cause the chrome to peel. I have seen it work its way under the tire bead and cause the wheel to not hold air.
Old Oct 11, 2005 | 10:37 PM
kartracer55's Avatar
kartracer55
Well Its not always about cracking the rim... but breaking/stripping the stud. Usually torque specs are between 80 and 110 ft lbs for aluminum rims, but dont hold me too it, ive never done wheels on a mustang. Check the owners manual.
Jim
Old Oct 11, 2005 | 10:45 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: Tim37
Besides the fact it can explode when a tire tech is workin on the tire. We got a bulletin about that stuff.
Old Oct 11, 2005 | 11:35 PM
StickShifty's Avatar
StickShifty
i cracked a stud once, it sucks to put one back on.
Old Oct 11, 2005 | 11:44 PM
kartracer55
yup... ya gotta pull the rotor off... what a b*tch.
Jim
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
robcy
Suspension
Oct 27, 2015 11:14 PM
Dan04COBRA
Sep 30, 2015 11:46 AM
tmdm
Sep 18, 2015 03:10 PM
LivingInThePast
Sep 16, 2015 12:20 PM
