rebuild failure?
Old Oct 12, 2005 | 12:25 AM
meshow99's Avatar
meshow99
Default rebuild failure?
I am attempting to rebuild my 5.0. i had the crank turned .010 and .010. I assembled the crank and that went well. I got the pistons in and just torqued the rod caps. Now I cant turn the crank whatsoever. I checked the plastiguage. The clearance is within spec. what gives? I measured everything. I am truly frustrated
Old Oct 12, 2005 | 12:45 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: rebuild failure?
Just to check the basics. Do you have the chamfer on the rods facing the right way? Did you set the crank end play? Bearings are the right size? Did anything go together hard?
Old Oct 12, 2005 | 11:09 AM
Chopper's Avatar
Chopper
ORIGINAL: JD1969
All these things and after you take everything apart again,try turning the crank after installing each rod.This way you won't have to tear everything apart again.
Old Oct 12, 2005 | 11:11 AM
meshow99's Avatar
meshow99
I am reusing the stock pistons as they are the TRW (factory) forged units. i will have to check that the rods are all in correctly I was too frustrated last night to figure it out so I quit. nothing went together hard.. everything rotated when the rod bolts were finger tight, but after torquing them to spec I couldnt budge the crank.
Old Oct 12, 2005 | 12:03 PM
JD1969's Avatar
JD1969
ORIGINAL: meshow99
I bet that you have one or more of the rods in wrong. You have what is called a chamfer on the crank, if you look close you will see it where the rod journal mees the counterweight, it is not a perfect 90 degree angle, instead it is slightly rounded. Next look at the rod with bearing installed, you will see that one side of the rod is machined to match up with the chamfer.
Look at the arrow in this image they refer to the radius which is what I am talking about, don't pay attention to the oil hole chamfer they refer to.
[IMG]local://upfiles/7038/B221CE86FD90411DBD6CCD6C9362985B.jpg[/IMG]
Old Oct 12, 2005 | 10:41 PM
meshow99's Avatar
meshow99
Guys- Not that it matters, but i did have the number 7 and 8 pistons in the wrong cylinders. I fixed that. I also did have the number 5 piston in wrong and the number 4 cap on wrong. Thank you so much for your time. You guys rule!
Old Oct 12, 2005 | 10:59 PM
kartracer55's Avatar
kartracer55
did ya use assembly lube? just thought Id ask.......
Old Oct 13, 2005 | 01:42 AM
JD1969's Avatar
JD1969
ORIGINAL: meshow99
That will do it.
1TUFF302
Nov 5, 2015 04:02 PM
Dathan
Oct 5, 2015 05:52 AM
Drastang
Sep 30, 2015 03:48 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
