Underdrive Pulleys
Old Oct 18, 2005 | 10:31 AM
Chopper's Avatar
Chopper
Default RE: Underdrive Pulleys
ORIGINAL: KillSwitchNY
so if i were to go with the steeda pulleys i wouldnt have to worry about everything you just explained about using piggback pulleys?
also with the underdives, what kind of performance increase can i explect, i know HP is supposed to boost 8-10 hp but what about throttle response/ accelartation being that there is less resistance from the water pump and alternator?
One more thing that no one mentions is the longer life of the accesories.The water pump on the Lincoln had 167,000 miles on it when it was traded.So didn't everything else except the alternator and the problem with it wasn't related to the pulleys.They were a weak link when they were new.
Old Oct 18, 2005 | 10:34 AM
grabbem88's Avatar
grabbem88
i use under drives minus alt.pulley (chucked it)power master alt 160amp.and a system.
not a glitch or any charging problems.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
spdeplayer2
Oct 24, 2015 09:45 AM
FivePointToTheOh
Sep 29, 2015 12:53 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
GimpyHSHS
Sep 18, 2015 12:27 PM
