Shifting Problems
Old Oct 17, 2005 | 06:17 PM
TorchV6's Avatar
TorchV6
Default Shifting Problems
Alright I have a long story but I will try to shorten it. I was driving dumb and shifting super fast a couple weeks ago. I missed thrid and hit first hard. I blew my clutch and needed a new one and a new pressure plate. I bought a new pressure plate and clutch disc, throw out, and pilot. I put all this in and also had my flywheel resurfaced. I got her all back together and now it is hard to shift into 5th but it will go in. If I get it into 5th and I go to downshift It is like it is stuck in 5th so I have to pull over stop and jiggle the hell out of it and then jam it into reverse to (what seems like it resets the tranny) get it back into 1st. the weird thing is shifting 1-2-3-4 or 1-Reverse is all fine I mean it is a little tight going into reverse but it has a problem coming out of 5th. What could it be? I put it all together correctly and I used an alignment to to get the clutch disc in there right. PLEASE HELP ME!!!
Old Oct 17, 2005 | 06:35 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: Shifting Problems
either synchro's or clutch is not disengaging all the way, make sure it's adjusted properly
Old Oct 17, 2005 | 06:39 PM
TorchV6's Avatar
TorchV6
yea thats what I was thinking at first but the clutch is not adjustable, I can buy a adjustable linkage but thats another $100. that I dont have right now. So is there anything else I can do to change it? Thanks
Old Oct 17, 2005 | 07:55 PM
TorchV6's Avatar
TorchV6
how about either over or under torquing my pressure plate?
Old Oct 18, 2005 | 01:24 PM
NITROSTANGRACING's Avatar
NITROSTANGRACING
Unfortunately understanding you do not have the extra 100.00 right now. The issue is in your adjustment. The factory linkage as you put it is plastic and goes bad. It will NOT allow your clutch to function properly. You really need to try and fine the 100.00 to get the aftermarket quadrant kit because if you continue to drive you will damage your clutch and then your transmission. Obviously costs more than the 100.00
Old Oct 18, 2005 | 04:13 PM
TorchV6's Avatar
TorchV6
ok thank you very much. I really appreciate all the help that you have provided.
Old Oct 18, 2005 | 04:18 PM
NITROSTANGRACING
Not a problem. Who are ytou getting the kit from? I have them in stock and ready to ship if you need.
Old Oct 18, 2005 | 06:54 PM
TorchV6's Avatar
TorchV6
well I am going to tear the tranny out and rip it apart one more time and if we see nothing wrong and after I make sure I installed it all right and it still wont work then i will let you know. But how much are you selling them for? just incase I do need one, not sure yet though.
Brandonfilipponi@yahoo.com
Sep 12, 2015 11:39 AM
Mustangmalo
Sep 6, 2015 05:22 PM
5.0 kevo
Sep 3, 2015 06:24 PM
