Sponsored by:
Sponsored by: DashLynx
New tires and rims : posts to small
Old 12-18-2014, 10:59 PM
jayWV
jayWV's Avatar
Default New tires and rims : posts to small
I have a 2001 V6 mustang and was given a set of tires and after market rims. They are p245/50 r16. The lug pattern is correct but the posts on my caliber aren't long enough to get a nut on. They arnt mags just need new posts but cant seem to find any that will work at the local auto stores... Any ideas or info on where to find some / how to go about this would be much appreciated. THANKS
jayWV is offline
Old 12-18-2014, 11:47 PM
99GTvert
is my username.
99GTvert's Avatar
By posts do you mean the lugs? Seems as if the offset of the wheel is way off if there arent enough threads left to put the nuts on.
99GTvert is offline
Old 12-19-2014, 07:31 AM
88 orangepeel notch
88 orangepeel notch's Avatar
The lugs are replaceable, but shouldn't need to be with rims that are designed for that car. I'd investigate those rims a little more. Search this forum or Google what offset you can run.
And welcome to the forum, hope we can help you out.
88 orangepeel notch is offline
Old 12-21-2014, 08:06 PM
jayWV
jayWV's Avatar
Thanks for the replies...
1. I know the "lugs" are replacebale.. I'm specifically talking about the posts that come off the calipers that go through the 5 lug pattern on my rims... The rims I have are offset but unfortunately cannot find any specifications for them. I'm only on 100 on the rims and tires so Im about to sell them and just buy some new tires and keep the factory rims on. The only other option I can see viable (unless some one can direct me to a place to buy new posts that are longer) is wheel adapters.
jayWV is offline
Old 12-21-2014, 08:09 PM
jayWV
jayWV's Avatar
Default new rims
I know the "lugs" are replacebale.. I'm specifically talking about the posts that come off the calipers that go through the 5 lug pattern on my rims... The rims I have are offset but unfortunately cannot find any specifications for them. I'm only in $100 on the rims and tires so Im about to sell them and just buy some new tires and keep the factory rims on. The only other option I can see viable (unless some one can direct me to a place to buy new posts that are longer) is wheel adapters. Again, I don't have any experience installing after market rims but did a good bit of research on offset and tire dimensions.
jayWV is offline
Old 12-22-2014, 07:13 AM
88 orangepeel notch
Don't take this the wrong way as I mean no disrespect..... but I have no idea what your talking about now. If you could post up a pic of these posts that come off the calipers, maybe we can sort this out.
Old 12-30-2014, 05:43 AM
dawson1112
dawson1112's Avatar
Your looking for wheel studs, not posts, and they are not connected to a caliper. They are pressed into the hub. I believe you will need to go to a 3 or 3.5 inch stud and use open ended lug nuts.
I think the stock ones are 1.75"
http://www.cjponyparts.com/arp-wheel...1973/p/HW1175/
http://www.cjponyparts.com/wheel-stu...2004/p/HW2456/
dawson1112 is offline
Old 12-30-2014, 02:06 PM
cruisin5268d
cruisin5268d's Avatar
Welcome to the forum. A picture can be very helpful with an issue such as this.
cruisin5268d is offline
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
whatsup62
10-16-2015 03:07 PM
MusicCity615
09-12-2015 07:05 AM
M3hunter
09-05-2015 03:42 PM
Quick Reply: New tires and rims : posts to small
