Rear end questions
Old May 4, 2015 | 05:12 PM
Kaleb's Avatar
Kaleb
Default Rear end questions
I have a question so here is the scenario
I have a 02 v6 obviously a 7.5, now I have a 98 8.8 rear that I want to put under it. I have the gear set I want which is 3.73. The axles count 28 spline but my new pinion counts 30....I counted 4 times using a marker. They are from ford racing and they are ten bolt.
Am I missing something? Or does the piece that locks the pinion in place come in 30? I know ford is 28 and 31
American muscle can't really help, ford racing won't help because they go by part number.
Old May 5, 2015 | 04:53 AM
petrock's Avatar
petrock
The pinion doesn’t have splines and doesn’t come in direct contact with the axles. Do you mean the spider/side gears? Those are the gears that the axles slide into. If so, you can purchase replacement spider gears with the number of spines that fit your axle shafts. Good luck...
Old May 7, 2015 | 03:55 PM
Kaleb's Avatar
Kaleb
Since when does it not have splines? Ever since I have ordered them you have to order by gear size, rear end size and spline count. Im going a different direction any way now. I'm keeping the 7.5 and selling the 8.8
Old May 8, 2015 | 06:59 AM
88 orangepeel notch's Avatar
88 orangepeel notch
The pinion gear is the one that essentially bolts up to the driveshaft. There are no splines on the pinion. Or you you meaning the actual gear teeth ?
Maybe we're not understanding you, but petcock gave a pretty good explanation.
Old May 9, 2015 | 03:16 AM
petrock's Avatar
petrock
Thanks… but it’s petrock. :-)
Old May 9, 2015 | 09:14 AM
Kaleb's Avatar
Kaleb
Then what is this? When I talked to American muscle we talked about the pinion spline count. The driveshaft itself has splines that go to the transmission.
Old May 11, 2015 | 06:47 AM
88 orangepeel notch
LOL, OPS!!! Sorry, I didn't catch that. Sometimes my thumb moves faster than my eyes.
Old May 11, 2015 | 07:00 AM
88 orangepeel notch
And thanks for the pic Kaleb, that helps a lot. Those splines mate to the U-joint housing, that gets bolted to the driveshaft. I'm not that familiar with the 7.5, but if your swapping to the 8.8, a quick Google search will tell you if you need to keep your old housing to put on the 8.8, but I wouldn't think you would need to, unless the 8.8 runs a bigger u-joint. Which makes sense now lol. Good luck
Old May 17, 2015 | 06:38 AM
dawson1112's Avatar
dawson1112
The 7.5 and 8.8 use a different Pinion Yoke. The 8.8 pinion yoke is slightly larger than the 7.5.
GimpyHSHS
Aug 29, 2015 06:30 PM
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
ding56
Aug 14, 2015 02:40 AM
92 5.0stang
Aug 13, 2015 06:46 AM
