Help with a heater/engine temperature problem
Old Jan 14, 2016 | 07:19 AM
All4One's Avatar
All4One
Default Help with a heater/engine temperature problem
When I start my car it is taking 7-8 minutes of driving for the heat to kick in. If I start it early and leave it idling to warm up nothing happens. I've left it for 20-30 minutes trying to diagnose, but it doesn't get warm. For the first 11 years I've had the car it would warm up normally where the heat would gradually get hotter and hotter.
I've replaced the thermostat, but getting the exact same result.
I uploaded a video since I'm really not sure how to explain it. Basically no heat blows out until 1:08 in the video when the gauge drops back down to between the N and O of normal where it has always operated. This is taking 7 minutes of driving and all the heat comes at once. It used to gradually put out more heat until it was up to operating temp even at idle.
Thanks for your help. What do I need to fix or check next?
Old Jan 18, 2016 | 04:22 AM
WhiteMule's Avatar
WhiteMule
Try replacing the coolant temperature sensor, it can be the sensor is faulty or maybe there is air in trapped ur cooling system where the sensor is reading trapped air bubble instead of Coolant.
Old Jan 18, 2016 | 09:30 AM
Urambo Tauro's Avatar
Urambo Tauro
I too suspect an air pocket, especially since the thermostat has been replaced. Don't replace the sensor without testing it first. Its resistance changes with temperature (there should be a chart somewhere around here...).
EDIT: ECT Testing
Old Jan 18, 2016 | 03:23 PM
DRAGUL's Avatar
DRAGUL
Also agree with the air pocket scenario. That did not read normal, temp came up to quick.
87 T TOP GT302
Dec 18, 2015 09:30 AM
Blanket
Dec 2, 2015 09:11 AM
Offendant
Oct 31, 2015 08:47 PM
99GTvert
Oct 25, 2015 06:47 PM
Mustang Videos
Oct 22, 2015 07:00 AM
