Rack & pinion leak..
Old Oct 23, 2005 | 12:19 PM
GreyStang's Avatar
GreyStang
Default Rack & pinion leak..
I saw yesterday the passenger side rubber boot on my '02 GT rack & pinion steering assembly is leaking fluid, it must have a rip in it or something [:@]
Is this easy to fix? Just replace the rubber boot with a new one?
Old Oct 23, 2005 | 04:36 PM
03YellowPony's Avatar
03YellowPony
Default RE: Rack & pinion leak..
The boot is just a dust cover. You can replace it, but the leak will still be there. You need to replace the seal. If you've never done one, I don't recommend you try it. Take it to someone who knows what they are doing.
Old Oct 24, 2005 | 12:44 AM
GreyStang's Avatar
GreyStang
Ok thanks. So, this seal can be replaced and not have to swap out the whole rack & pinion?
I had noticed my power steering fluid level had dropped a bit in the past couple weeks,, guess I know found out where the fluid was going
Old Oct 24, 2005 | 01:54 PM
Tim37's Avatar
Tim37
some times it is easier to replace the rack it really depends on what is leaking but it does need fixed.
Old Oct 24, 2005 | 06:59 PM
GreyStang's Avatar
GreyStang
Well I stopped by the dealer today.. He says the whole rack&pinion needs to be replaced without even looking at what's wrong,, just from hearing me describe that fluid is leaking from the passenger side boot..
Hey gu-esstimates it will be around $500-600 (Canadian!) for them to do the work [:@]
If the whole rack needs to be replaced, I'm thinking to just go grab a rebuilt unit & do it myself!! How much of a pain in the **** is swapping out a rack&pinion assembly? Any "special" tools needed above the basic wrenches/sockets etc?
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
KingRando
Oct 2, 2015 08:06 AM
allenmaty
Sep 24, 2015 09:17 AM
Blk Vert
Sep 9, 2015 12:16 PM
