Problem with o/r X-pipe 03 Cobra
Old Oct 27, 2005 | 01:32 AM
Pitboy's Avatar
Pitboy
Default Problem with o/r X-pipe 03 Cobra
I just installed an x-pipe on my '03 cobra (supercharged) and it is running like crap. I read the posts about the MIL eliminator but my check engine light has not come on yet. I did start the car a couple of times with just the x-portion of the pipes connected and no mufflers to check for leaks at the shorty headers and the x-pipe. Then I connected the rear portion and started it up. It was definitely louder and had that "tingy" sound that flowmasters typically make. But then as I drove out of my yard I heard it sounded like it was pinging at only about 2500-3000 rpms. WTF!!!! Is this all part of the MIL eliminator??? I have read several people have problems with these MIL Eliminators not working properly. I read you can just make one for about a buck how do you do this so I can see if this will fix the problem before spending $60 on a BBK MIL Eliminator. Any help would be greatly appreciated.... Also do I need to maybe unplug the battery to reset anything??? I dont have one of those trouble code computers....
Old Oct 27, 2005 | 01:41 AM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: Problem with o/r X-pipe 03 Cobra
You can disconnect the battery for about 10 minutes and re connect to reset computer. A tuner would be better to get vs. the mil`s. Therefore the tuner will be able to turn off the rear 02 sensors if needed. After installing the midpipe, that shouldnt make the car run like s***.
Old Oct 27, 2005 | 01:52 AM
Pitboy's Avatar
Pitboy
Well a tuner may be in the future but I need to get this problem fixed so I can get back and forth to work for the next few days. I read a little more about this and I see that when this O2 trouble occurs its supposed to put the computer into "LIMP" mode. To reset this I simply unplug the battery for 10 minutes?
Old Oct 27, 2005 | 07:56 PM
NewMexMustang's Avatar
NewMexMustang
When the 02 sensors are picking up strange reading they will try and compensate in the fuel mixture. I would get the MIL's as sooner or later your will have trouble w/ those rear sensors.
Old Oct 27, 2005 | 07:58 PM
Tim37's Avatar
Tim37
do you have your o2 sensors hooked up? if they aren't it will cause you problems.
Old Oct 30, 2005 | 10:37 AM
shane361's Avatar
shane361
I have a Diablo tuner I will sell you. I can even get a custom tune from a tuner friend. Do the battery thing as suggested..it resets things and the PC will learn them again. Sounds like your mils are bad or atleast one-Shane
2007CalSpec
Dec 13, 2020 11:42 AM
Nov 10, 2015 11:39 AM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
Sep 8, 2015 06:25 PM
Sparks_88
Sep 8, 2015 01:06 PM
