High Oil Pressure
Old Oct 28, 2005 | 12:16 AM
97_GT_Muscle's Avatar
97_GT_Muscle
Default High Oil Pressure
I had an electronic oil pressure gauge installed and until the car reaches a temp of approximately 150 degrees the gauge is pegged at 100PSI. Once the car reaches temp, the gauge settles at 50PSI for cruising speed and 25PSI for idle. The thing that really concerns me is that when the car is pegged at 100PSI (below 150 degrees) and I rev it, I blow oil out of the valve cover breather. Is this normal for an engine like mine?
Old Oct 28, 2005 | 01:44 PM
firststang@17's Avatar
firststang@17
Default RE: High Oil Pressure
No that is not normal. I have an automer oil pressure gauge and the highest mine goes is 60psi. and thats only during start up. she idles at 45psi. I dont know waht could cause the problem though..
Drive hard, Drive fast, Drive smart!
87GT
347
5 speed
im tired of listing everything
Old Nov 3, 2005 | 12:22 PM
turbostang21's Avatar
turbostang21
i have a high volume oil pump...so mine never drops below 40psi and i peg the gauge on start up. ask what pump they used when you had your motor built. your oil pressure sounds fine to me, high = ok; low = panic. i would add a breather or two to help release some crankcase pressure. i blew oil out of the dipstick under boost until i ran 3 lines(2 pass, 1 drivers valve cover) to an oil catch can with a breather. i was worried as hell when it first happened until i researched it and found many people who had the same problem until they added up to 4 breathers. any smoke out of the exhaust?? if you go with breathers, i would recommend the ones that are two piece, so that it screws together and preferably with baffles. good luck and let us know how it works out
CS2007
Jun 25, 2019 09:45 PM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Drastang
Sep 30, 2015 03:48 AM
wraith777
Sep 28, 2015 10:49 AM
