Question about a 1994
Old Apr 8, 2018 | 05:35 PM
Foxinsoxx's Avatar
Foxinsoxx
Default Question about a 1994
Hello all, I am hoping someone can help me out here as I have no idea where to start. In late October my sister suddenly passed away and my brother in law gave me her 1994 mustang. It has a brand new battery in it but it still continuously dies and needs to be jumped even if its only been a few days since it was last started or driven. I really want to hang onto this vehile and keep it running but I was hoping someone could give me advice on what other things may be causing this issue so I have an idea of where to start to get this fixed.
My brother in law thinks it was caused by the alarm on it somehow draining the battery and he said he disabled it but I'm not certain how that could still be affecting it of that's the case?
I appreciate any input on this as it is a really super sentimental vehicle for me that I really want to keep going... but I'm also on a budget especially when it comes to dumping tons of money just to figure out where to start...
Old Apr 8, 2018 | 05:59 PM
pure_kaos's Avatar
pure_kaos
Jumpstart the car, let it run for a few minutes and then remove the negative battery cable while its running. If it dies then you have a faulty alternator.
Old Apr 8, 2018 | 06:03 PM
Foxinsoxx's Avatar
Foxinsoxx
Thank you! I'm definitely going to try this one out
Old Apr 8, 2018 | 09:57 PM
Urambo Tauro's Avatar
Urambo Tauro
Four things to check:
The battery itself must be charged, it must hold a charge, and it must be able to pass a load test.
All cables & connections must be clean and secure, able to deliver current from one end to the other with minimal resistance.
The alternator must deliver a charge voltage of 13-14 volts while the engine is running.
The car must not have a drain of more than 50 mA from the battery when the car and all of its accessories are shut off.
Old Apr 9, 2018 | 08:06 AM
Foxinsoxx's Avatar
Foxinsoxx
That's all over my head lol but thank you. At least I'll know what to ask someone to check so I'm not totally clueless or taken for a ride by someone trying to make some money. Thank you!
Old Apr 9, 2018 | 08:19 AM
Stepman's Avatar
Stepman
It's most likely the amp is not turning off. Look for the fuse, I think its under the hood. Don't remember if it's the same as the stereo or a separate one. Should be listed in owners manual. Pull the fuse and see if it still starts in a couple days. If it does, you have a bad amp. It can kill a battery in about 2 days or less.
Old Apr 9, 2018 | 12:55 PM
Foxinsoxx's Avatar
Foxinsoxx
Thanks, this sounds like a really promising place to start... and something I can figure out myself. Really appreciate the input. Definitely going to give this a check
Old May 18, 2018 | 08:27 AM
Stepman's Avatar
Stepman
Did you figure this one out yet?
snkyt
Mar 24, 2012 12:28 PM
futuremustang
Jun 1, 2006 02:56 PM
Cyberwolf1986
Nov 6, 2005 06:19 PM
NeoTokyo
May 2, 2004 02:21 PM
