Backfire issue
Old May 16, 2018 | 06:58 PM
Austinbs's Avatar
Austinbs
Default Backfire issue
So my 2007 gt will sputter and then backfire at 5k to 6k rpms in 3rd gear, 4k to 5k in 4th gear, and 2k and on in 5th gear. There is no check engine light and my tuner isn’t reading any codes. Anyone have this issue before or have an idea what it could be?
Old May 18, 2018 | 11:35 AM
Z28KLR's Avatar
Z28KLR
Backfiring (loud, almost violent "bang" sound) or misfiring? Two different things.
From what you describe it sounds more like misfiring. The go-to's there would be check and replace as necessary ignition components such as spark plugs and coils. Since you have no cylinder specific trouble codes I would concentrate on plugs and inspect the coil boots, which can be replaced individually as needed for about $10 apiece. Look for any signs of deterioration, if you see a brown-ish dust like substance on the boots then that is indicative of current arcing through.
Old May 18, 2018 | 11:37 AM
Z28KLR's Avatar
Z28KLR
And if it's not been done recently or ever, fuel filter. $15 and about as many minutes of your time to replace. Maybe dump a bottle or two of Techron in the tank as well.
Old May 18, 2018 | 12:35 PM
Austinbs's Avatar
Austinbs
Thank you, I’ll try these repairs and see if anything changes. Thanks for your time
uberstang1
Jul 26, 2018 08:23 PM
07BOSSGT_S197
Nov 21, 2007 12:26 PM
tchamber
Jan 14, 2004 09:13 PM
tchamber
Nov 9, 2003 05:47 AM
lebrush
Nov 9, 2003 12:49 AM
