Sponsored by:
Sponsored by: DashLynx
Brake lights issue
Old 08-07-2018, 06:30 AM
CadenOquinn
CadenOquinn's Avatar
Default Brake lights issue
Ok so my running lights work(when I turn on my headlights they turn on,they are the same bulb as the brake lights) but whenever I press my brakes they don’t get brighter . When I use my blinker they do and my hazards so the bulbs are fine but I can’t figure out why they just stoped working .is there a fuse or a ground I can check (2007 gt)
CadenOquinn is offline
Old 08-07-2018, 11:59 PM
kevsgt
kevsgt's Avatar
Are you the first owner? Were aftermarket sequential light turn signals ever installed?
kevsgt is offline
Old 08-08-2018, 12:26 AM
CadenOquinn
it’s stock lights
Old 08-08-2018, 08:02 AM
Stepman
Stepman's Avatar
Check the brake light switch?
Stepman is offline
Old 08-08-2018, 04:13 PM
CadenOquinn
I don’t think it’s the brake switch because if I put on cruise and press the brake it works
Old 08-09-2018, 08:10 AM
Stepman
Stepman's Avatar
May still want to look. With the computers today there may be things run different off the same switch. The boo, the shift interlock, and lights could all be separate.
Stepman is offline
Old 08-09-2018, 03:54 PM
CadenOquinn
what exactly am I looking for.like how do I check to make sure it’s working
Old 08-09-2018, 06:08 PM
08'MustangDude
Banned
08'MustangDude's Avatar
According to the diagram, the brake switch is a single contact, so if your cruise
deactivates when you press the brake pedal, then it is physically working.
There is a fuse in the SBJ for the brakes; fuse 15 "Stop Lamp Switch"
Does your center brake light work? That is on a separate wire from the SBJ.
08'MustangDude is offline
genec728
04-14-2021 11:09 PM
davesiar
03-20-2018 02:26 PM
JohnnyD70
05-05-2016 09:01 AM
Jwebber
08-28-2013 07:45 AM
franckybosnie
03-30-2007 11:44 PM
Quick Reply: Brake lights issue
