problem with brake light ......
hi everybody
Got a little problem with my 89 lx 5.0L . When I press the brake pedal , my brake lights works but the flashers comes in . They don't flick but I see the left and right arrow for the flashers getting illuminated.... What would it mean?
thanks
thanks
RE: problem with brake light ......
Burnt bulbs in the front most likely. Have you gotten out of the car when you turn the blinker on to see if both front and rear lights are on? if the fronts are out then that's why it's not blinking. Replace the bulbs or the fuse associated with the parking lights (also runs the blinker lights on the front) and that should take care of it.
Okay..let's take a step back.
Blinkers don't flash right when you hit left or right, right?
When you press on the brake your front blinker lights come on with them?
Do your hazard lights work when you press the hazard light button(Light and blink)?
Its hard to explain .... sorry my english is bad .... I speak french Again , if I don't press the brake , hazards works well . If I don't press the brake ,left and right flashers works well , outside and the signal inside . Anytime I press the brake , my brake light comes on , BUT hazard lights comes on too , but they don'T flick, they just light on (inside signals , the geens arrow) and outside .
any Ideas? When I press the brake , my front markers lights on . Hazards works fine , but now , my left flasher works fine , but the right one suck . When I put the right flasher , it flasheh wery low , BUT the left flashers light on too .... I don't know what to think .....
bond007
08-26-2015 11:36 PM
