Seized engine on 99'
Old Jun 11, 2020 | 08:31 AM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
The bottom pulley is the one you want to rotate to the right. You can usually go back to the left if everything is jiggy with the engine but it sounds like it isn't so like the song says, to dah right, to dah right, to dah right, to dah right. To make rotating the engine easier, pull some or all of the spark plugs.
You won't see anything external moving while you are rotating the crank shaft other than the pulley but what you're trying to verify is that the engine is not seized so if it keeps rotating at least it isn't seized. It could still be phucked, but at least it isn't seized. You shouldn't need an insane breaker bar to spin the engine but if you can only rotate it so far before it stops moving then Houston, we have a problem and it is going to take some open heart surgery to figure out.
BlueFin
Jul 1, 2020 10:53 PM
BlueFin
V6 General Discussion
Jun 2, 2020 07:41 AM
Sash
Nov 18, 2009 09:09 PM
TITAN
May 2, 2006 08:10 PM
buytheredcar
SVT Forums
Dec 17, 2005 03:28 AM
