A hard to answer question and a not so hard...
Old Nov 1, 2005 | 10:57 PM
tuff5liter's Avatar
tuff5liter
Default A hard to answer question and a not so hard...
have a 1991 GT Hatchback. Here are my mods....
BBK Cold Air Induction, 75mm Mass Air Flow Sensor, BBK Shorty Headers, BBK Off Road X-Pipe, Flowmaster 2 Chamber Mufflers, BBK 190 LPH Fuel Pump, FRPP 3.73 Gears, Wolverine/Blue Racer 1087 cam (289/299 duration with a 510/534 lift), 70mm Throttle Body, Steeda Upper Control Arms, Custom Digital Dash, and Granatelli Weight Jacker Lower Control Arms.
I am running WAYYYY rich. I put my car on the emissions machine at school and my HC's are way up in the 2500 range. I still have all of the normal emission equipment on my car (minus the cats), I dont think the cats would bring down the HC level bc i believe those are only for NOx. The only thing I can think of maybe that my cam is to big for my stock heads and intake. Im not real worried about getting a sticker in El Paso, but this next september I am moving back to Dallas, and from what I understand, they use the dyno now for the emissions test. I have thought about getting an E cam to replace the cam I have but I LOVE the way it sounds. Here is a link to a discussion about this cam in a 1994 lightening.
http://64.22.203.126/forum/showthrea...&postid=654285
Any advice to lean this car out would greatly help me out more than you will know. Thank You.[sm=dontgetit.gif]
Now for the easier question....
I currently have 3.73 gears, and I hardly noticed a difference to the stock 3.08 ratio. I have a gear whine in 4th gear at 35 mph, and I am assuming that it is because I let a "Retired Ford Mechanic" install them in his backyard, and also the gears were "slightly used." Since I want to replace the gears with a new set, how much of a difference will a set of 4.10 gears make compared to the 3.73's? Thanks :-)
Old Nov 2, 2005 | 01:16 AM
mkspeed26's Avatar
mkspeed26
Default RE: A hard to answer question and a not so hard...
the cam is definately on the agressive side, especially with stock heads and intake. that size cam is usually more high-rpm range, which stock heads and intake will not support. so either look into getting new heads and intake, or drop the cam down a little.
or, if you still have the stock midpipe, just bolt that on there for the emissions test and swap it out later
edit: it isnt as big as i originally though. looking at the other specs on the website, i dont think the cam is necesarily too big. how is ur igntition setup?
Old Nov 2, 2005 | 02:16 AM
tuff5liter's Avatar
tuff5liter
ORIGINAL: mkspeed26
The cats are just for NOx if i did my research correct, I still have the stock h pipe and will use that for my emissions testing. As for my ignition I just bought a MSD 6AL but I havent installed it just yet. Do you think this will help burn the fuel completely?
Old Nov 2, 2005 | 10:58 AM
mkspeed26's Avatar
mkspeed26
http://auto.howstuffworks.com/catalytic-converter2.htm VOCs stands for Volotile Organic Compounds, which is the same as HCs (look at the previous page of the article). catalytic converters do reduce HCs
Old Nov 3, 2005 | 01:04 AM
tuff5liter's Avatar
tuff5liter
ORIGINAL: mkspeed26
Well Ill be damn.....but i like not having Cats Do you know of a good hi flo three way catalytic converter, I could purchase for a decent price?
Old Nov 3, 2005 | 02:15 AM
mkspeed26's Avatar
mkspeed26
go to summitracing.com, then type in part # MPE-93338 for the 2.5" version or MPE-93337 for the 2.25" version. i dont know how good they are, but it is pretty much all i could find
04stangman
Sep 17, 2015 01:45 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
TheDutchTexan
Mustang Videos
Sep 10, 2015 06:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
