2013 3.7l Overheating
Old Aug 10, 2022 | 10:13 AM
wrobdog's Avatar
wrobdog
Default 2013 3.7l Overheating
Hello,
I'll try to keep it short, my nephew bought a 2013 Mustang v6 3.7l automatic with 85k miles. Couple days later the vehicle overheated, we replaced the t-stat and water pump took it for a test drive and everything seemed fine, no leaks, temp gauge was normal so we assumed problem solved. Next day, driving around with AC on the temp gauge spiked to red so he pulled over and turned it off. Parked with AC on the high speed fan starts but i'm not 100% sure it's not shutting off at some point, what i can't figure out is the low speed fan, we ran the vehicle for 30min on a 90deg day and the low fan never came on. The fuse looks good and we verified the relays by swapping them out with the windshield wiper relay, i removed the fuse box looking for burnt or bad connections, nothing. I removed the fan connector and verified 12v on high speed but nothing for low speed. I don't have a handheld programmer or software to force the low fan to come on. My nephew is pretty upset that he can't drive the mustang so any help would be appreciated.
One a different note but related, we found a service invoice from FORD where the previous owner reported overheating, they replaced the fan and called it good. Does anyone know if a service repair warranty is transferrable to new owners?
Thanks,
Rob
Old Aug 10, 2022 | 07:59 PM
dirtwarrior's Avatar
dirtwarrior
Is the fan actually coming on
Old Aug 11, 2022 | 04:35 AM
wrobdog's Avatar
wrobdog
Yes, but only when the AC is on.
Old Aug 11, 2022 | 04:56 AM
royjj12's Avatar
royjj12
Try calling the shop that did the repair. I doubt if the service warranty is transferrable for a 2013, unless it was specified in the service contract. However, they may be able to assist you in diagnosing the problem. Are you getting any codes or check engine light when it overheats?
Last edited by royjj12; Aug 11, 2022 at 04:59 AM. Reason: hit a wrong key before I was finish with my post.
Old Aug 11, 2022 | 06:37 AM
JimC's Avatar
Super Moderator
My 2013 had this same issue and it wasn't the fan but the relay that failed.
Old Aug 11, 2022 | 09:05 AM
wrobdog's Avatar
wrobdog
royjj12 - Call the repair shop for assistance, good idea. No codes or check engine light.
JimC - You mentioned the relay, I verified that both fuse box relays are good, are you referring to another relay?
Others mentioned a dropping resistor that controls the low fan and the temp sensor, any idea the location and how to test it?
Thanks,
​​​​​​​Rob
Old Sep 2, 2022 | 09:42 AM
wrobdog's Avatar
wrobdog
Update on the overheating issue.
We removed the fan pigtail and discovered that either the previous owner or the car lot where he bought the vehicle tried to replace a bad wire, probably the worst solder job I've ever seen. We bought a new pigtail and the young man is back on the road.
Thank you for all the replies.
Goldenpony
Jul 11, 2021 09:45 AM
Mbgarrison
Jul 17, 2019 08:50 AM
wjalex4
Aug 2, 2017 10:38 AM
alam
Aug 25, 2013 09:55 PM
Zac1987
Nov 15, 2007 06:04 PM
