2008 ford Mustang 4.0 V6 Automatic
Old Oct 13, 2024 | 06:15 PM
Cschuyler's Avatar
Cschuyler
Default 2008 ford Mustang 4.0 V6 Automatic
These three codes pop: p060B, p2104, & p2110.
the pedal and throttle body have been replaced.
everywhere I have asked says it’s the pcm or wiring.
wiring is intact. No signs of wire damage.
is there a way to be for sure?
so what is happening is when I am driving it the wrench light will pop and it will go into limp mode.
once I shut it off and turn it back on it drives normally again. After doing this three times the codes pop.
always the same codes. About 15miles between
if I re-set the system (disconnect the battery) it will drive 50-70 miles before it happens.
anyone have this issue before?
Old Oct 13, 2024 | 06:36 PM
05stangkc's Avatar
05stangkc
I would Swap 02 Sensors From Side To Side if Able & See if Code For Banks Change. If So You Got a Bad 02!
Here Are The Ford Shop Manual DTC Code References
P0060 - HO2S Heater Resistance (Bank 2, Sensor 2)
Description: See the description for{ DTC P0053.} Possible Causes: See the possible causes for DTC P0053. Diagnostic Aids: See the diagnostic aids for DTC P0053. Application Key On Engine Off Key On Engine Running Continuous Memory AllP0053 - HO2S Heater Resistance (Bank 1, Sensor 1)
Description: Heater current requirements too low or high in the heated oxygen sensor (HO2S) heater control circuit. Possible Causes:
  • VPWR circuit open
  • HO2S heater circuit open
  • HO2S heater circuit short in the harness
  • Damaged HO2S heater
Diagnostic Aids: Inspect the connectors for signs of damage, water ingress, or corrosion.
USE PINPOINT TEST DW See Pdf
P2104 - Throttle Actuator Control (TAC) System - Forced Idle
Description: The TAC system is in the failure mode effects management (FMEM) mode of forced idle. Possible Causes:
Diagnostic Aids: This DTC is an informational DTC and may be set in combination with a number of other DTCs which are causing the FMEM. Diagnose other DTCs first. Application Key On Engine Off Key On Engine Running Continuous Memory All
2110 - Throttle Actuator Control (TAC) System - Forced Limited RPM
Description: The TAC system is in the failure mode effects management (FMEM) mode of forced limited RPM. Possible Causes:
File Type: pdf
Old Oct 14, 2024 | 06:58 AM
Cschuyler's Avatar
Cschuyler
The code is p060B not p0060
P0060 is heater oxygen sensor.
P060B indicates Internal Control Module A/D Processing Performance
Old Oct 14, 2024 | 10:44 AM
05stangkc's Avatar
05stangkc
Doh!
Damn My Eyes For The B
KC
Old Oct 14, 2024 | 10:56 AM
05stangkc's Avatar
05stangkc
P060B - Internal Control Module A/D Processing Performance
Description: Indicates an error occurred in the powertrain control module (PCM). This DTC may set in combination with P2104 or P2110.
Possible Causes:
Damaged PCM
Diagnostic Aids: Inspect the harness for damage. Verify correct operation of the sensors using VREF and related circuits.
All — — GO to Pinpoint Test QE.
Maybe This Pdf Will Help!
These Interactive Manuals Are Great if You Actually Have Access All The Time But Stand Alone Can Be very Limiting!
KC
Old Oct 15, 2024 | 12:19 AM
Cschuyler's Avatar
Cschuyler
PDF leads me to replacing the pcm…
I guess I will try it….
I’ve contemplated that it could be a wire issue. But find none. Like maybe it’s intermittent….
I’ve looked for an engine wiring harness. Everywhere I look it says discontinued or not available.
if anyone can point me to one it would be greatly appreciated!
Old Oct 15, 2024 | 12:22 AM
05stangkc's Avatar
05stangkc
See Other Thread!
KC
Old Oct 15, 2024 | 12:39 AM
05stangkc's Avatar
05stangkc
Just For Grins I Have Seen Weird Things Happen With The Water Intrusion Issue in The SJB. Have You Checked For Signs of The Sjb Getting Wet? Everything Plugs into That Thing!
KC
Terryw
May 26, 2018 02:03 PM
Paratrooper34
Sep 5, 2016 07:57 AM
kritllsj
Jul 27, 2015 02:18 AM
downriverT
Jun 22, 2008 08:05 PM
raf702
Apr 10, 2007 08:10 PM
