compression calutator
Old Mar 7, 2007 | 02:09 PM
JMD's Avatar
JMD
Default RE: MAKE A STICKY LOOK IN SEE
Yea,,,, I did have a "math issue" I was failing to add the total cumbustion chamber volume to the cylinder displacement prior to dividing. OOPS.
So, I guess I will be running 11 to 1 instead of 10 to 1, hopefully my cam selection and the altitude I am at will help a little.
There are some cool calculators in this section.
Are you running at 13 to 1 CR? If so what are your octane requirements? To be honest I am a little concerned at running 11 to 1, even with my alum heads, my camshaft selection, and my home elevation of about 4,000 feet.
(I would like to hear that you have no problems running pump gas, but .... tell me the truth anyway, I can take it!!!)
Old Mar 7, 2007 | 09:54 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Yes, that is my 390HP. I run 91 octane pump gas and have taken out about 6 degrees of timing. It would definitely like more octane, but at 8 mpg, she isn't going to have a diet of racing gas. Only treats.
My 12.5:1 302 runs on 91 octane with about 4 degrees taken out.
I'm around 5k feet.
EDIT:
Forgot to mention a little known tidbit about your local octane rating. 91 octane gas in Denver isn't the same octane as 91 octane in LA. The octane rating uses the elevation of the target area in determining what the octane rating will be. This is part of the reason why your owner's manual says to use87 octane no matter what elevation you are at (at least my '03 GT says that). I'm pretty sure racing fuels aren't rated this way.
Old Mar 8, 2007 | 04:28 PM
hellas85stang's Avatar
hellas85stang
Default RE: compression calutator
my set up says about a 10.5 comp, the calculater says 10.3//// not enuff to makae a diff and make me mad ..lol i cam get a smaller gasket thickness nexttime..
Old Mar 12, 2007 | 12:05 AM
JMD's Avatar
JMD
Hmm...
So, then gas bought at a higher elevation should be cheaper to produce than gas sold at sea level,,, I don'timagine thatthe high elevation consumer ever sees this benifit...
Old Mar 19, 2007 | 03:41 PM
kenash's Avatar
kenash
Hey C/Note,
Here's another great calculatorL http://kb-silvolite.com/calc.php?action=comp
I found this while researching my own compresssion issue.
Thanks for this alternative.
Good luck
Old Apr 21, 2007 | 03:14 AM
Dyno_Ron's Avatar
Dyno_Ron
Here are a couple more:
http://www.virtualengine2000.com/ProgramDownload.htm
Old Apr 30, 2007 | 10:25 PM
MustangEnthusiast's Avatar
MustangEnthusiast
Nice, definitely book marking this
Old May 4, 2007 | 06:17 PM
the new nos/man's Avatar
the new nos/man
I ♥ Acer
ORIGINAL: kenash
Hey C/Note,
Good luck
thanks man .. dam i got 2500 hits , yes i was c/note at one time. its fairly close the link i had . like some one else said has anybody checked to a real blueprinted eng? i havent .all i got to be is close. with 262 / 274 at .050 lift.and .701 lift,it dont matter if i got 12to1 or 11.5 to1 on the spray baby 408w.
Old Sep 24, 2007 | 08:00 PM
johnnyhou's Avatar
johnnyhou
Is a calutator a hybrid between cauliflower and potatoes?
Old Sep 25, 2007 | 06:45 AM
kenash's Avatar
kenash
As so it may seem......Oh my, the pen is mightier than the sword!
Have a great day, anyway!
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
