Beating emissions test
Old Nov 12, 2005 | 05:04 PM
performance_stangs97's Avatar
Default Beating emissions test
Has anyone figured out how to beat the emissions test yet running the offroad H-pipes? When my gt is hooked up on the testing machine while i have my offroad h-pipe on, will the MIL eliminator give a "PASSING" code on my emissions (exhaust) or do I just need to keep my stock exhaust on??? because I sure as h### dont want to put it on and then 7 months later have to put my stock exhaust back on. Let me know. Thanks
Old Nov 12, 2005 | 06:07 PM
corvetteguy's Avatar
corvetteguy
Default RE: Beating emissions test
What about ASCITONE????
Old Nov 12, 2005 | 07:03 PM
Dan04COBRA's Avatar
Dan04COBRA
Are you getting the sniffer or just a scan to check for codes?
If you have MIL's and they check for any codes, you'll pass, the MIL's trick the computer into believing everything is working. If you have to pass a sniffer, you stand no chance.
Besides, it's not like it'll be some huge deal to swap mid-pipes for emissions? It'll take an hour tops to do it by yourself or 50-60 bucks to pay a shop to do it?
Old Nov 13, 2005 | 06:22 AM
true.....naw, they dont do the sniffer, just the computer testing, I appreciate your reply bro, I am going to do it in a couple of hours
ORIGINAL: Dan04COBRA
Old Nov 13, 2005 | 06:23 AM
ascitone?
ORIGINAL: corvetteguy
Old Nov 13, 2005 | 02:27 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: performance_stangs97
Umm...Sorry, but Cali DOES use a sniffer also. Along with the computer hook up. I ran 5 shops, 4 had smog.
Old Nov 13, 2005 | 05:47 PM
91stang's Avatar
91stang
one thing that i've heard but im not saying it's true by any means... is that if you put the shell around the O/R pipe and tune your timing down really low and you'll pass.
the theory behind this is that all the gases get burned up before they exit out. also they'll look under the car to see if the cats are there.
Old Nov 14, 2005 | 02:18 PM
Tim37's Avatar
Tim37
ORIGINAL: 91stang
won't backing the timing down making it fire closter to tdc make it burn less fuel since it is firing later in the rotation?
Old Nov 14, 2005 | 03:02 PM
91stang's Avatar
91stang
i'm just going by what i heard... if you're desperate it's worth a try i guess.
i didn't say that i'm sure it'll work just throwing it out there
Old Nov 14, 2005 | 03:28 PM
Dan04COBRA's Avatar
Dan04COBRA
Holy huge signature batman! D oyou think you can make it smaller man?
