gear selection advice
Old Nov 24, 2005 | 09:55 PM
  #21
dave86's Avatar
dave86
Default RE: gear selection advice
well, my tire size is the same. i was using 245/45/17 before. i'm using 245/40/18 now. cool.
Old Nov 24, 2005 | 10:08 PM
  #22
nanaki's Avatar
nanaki
Retired MF Moderator
whatever stang you have, 4.10 or bust. if you don't get 4.10s, you'll regret it later. there's no need to even ask.
Old Nov 24, 2005 | 11:50 PM
  #23
hunter9s's Avatar
hunter9s
Nice car, looks just like mine except convertible. I get more compliments on the color and the fact its a throaty Mustang.
ORIGINAL: angcobra
keep in mind the other part of the equation is tire size. When you compare to other cars you also have to know the tire size. You don't need as much gear if you run a short tire. Just to give an example;
3.73 rear gears with 26 inch tall tires
gives the same performance and top speed as
4.30 gears with 30 inch tall tires
Old Dec 3, 2005 | 08:59 PM
  #24
racerxxx98's Avatar
racerxxx98
4:10's all the way!!Don't be one of those guys that wished he went with 4:10s and by the way you shouldn't pay more than 200 labor for that kind of work.I spent $180 for the gears get the frp and $200 for labor.
Old Dec 4, 2005 | 04:47 PM
  #25
The Great Cornholio's Avatar
The Great Cornholio
I ♥ Acer
In spite of the previous comments about $300 being a ripoff, it isn't if the shop is supplying all new bearings, differential lube, friction modifier, and most importantly, does the job right the first time
Old Dec 4, 2005 | 05:01 PM
  #26
mustangman02232's Avatar
mustangman02232
with 4.10s your top end will actually be increased, you now have higher revs so when you shift into O/D at the end of 4th gear you will be in the powerband, so you will have like a whole extra gear, the reason people get crappy milage with 4.10s is because they have their foot in it more to because they make the car faster.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
