No oil pressure
Old Nov 25, 2005 | 06:28 PM
RP46's Avatar
RP46
Default No oil pressure
Newby here,
I'm looking for info regarding sudden loss of oil pressure in a '68 with a 289 2bbl/auto. There is oil in the engine. One stoplight it was ok next light slight ticking and 0 oil pressure.
I assume that I will need to drop the oil pan, crossmember, etc.
Anything special to know before I start?
RP46
Old Nov 25, 2005 | 06:52 PM
fordguy17's Avatar
fordguy17
Default RE: No oil pressure
your pickup could be clogged or the oil pump driveshaft could have broken.
Old Nov 26, 2005 | 01:01 AM
92hatchLX's Avatar
92hatchLX
Spun a main?
Old Nov 26, 2005 | 01:39 AM
cammedlx's Avatar
cammedlx
Or major cam bearing wear.
Old Nov 26, 2005 | 03:17 AM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
Aftermarket guage? Electrical or mechanical?
Take the filter off and cut it open...look for debris (metal, copper)
Report back....
Old Dec 4, 2005 | 02:12 AM
RP46's Avatar
RP46
Got it. Broken oil pump shaft, twisted up like a candy cane. Looks like the pump tolerances were a little loose and the pump jammed and twisted the shaft.
New pump, pan gasket set, 4 hours later, all done.
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
wraith777
Sep 28, 2015 10:49 AM
ccdguy
Sep 19, 2015 05:20 PM
SteelerNation82
Sep 16, 2015 07:11 AM
