overdrive
Old Nov 27, 2005 | 02:26 AM
01musgt's Avatar
01musgt
Default overdrive
can someone explain to me what is overdrive on a auto mustang, what does it do and is it better to race at the track with the overdrive on or off
Old Nov 27, 2005 | 04:26 AM
ShadowDrake's Avatar
ShadowDrake
Default RE: overdrive
Overdrive off at the track unless you're red-lining third by the end of the run. Overdrive is your 4th, overdriven gear (ratio numerically less than 1.0). When you turn your overdrive off you are stopping your transmission from shifting into 4th gear. An overdrive gear is best for high speed cruising, you have very little acceleration in overdriven gears.
Old Nov 27, 2005 | 03:40 PM
p0rsche23's Avatar
p0rsche23
i turn mine off when im foolin around or racing at top speeds because of my speed lmitier,as for the acceleration in the first 3 gears,i dont think o/d on or off affects this even tho it may seem it does..
CarrieS
Sep 1, 2015 01:00 PM
erig94gt
Jun 11, 2005 03:14 AM
BlackGT5.0
Feb 15, 2005 01:05 AM
89stanglx
Feb 3, 2005 11:17 PM
88_5.0
Dec 24, 2004 04:17 AM
