traction control
Old Dec 5, 2005 | 07:27 PM
OnyxCobra's Avatar
OnyxCobra
Default RE: traction control
yeah i heard you're only supposed to turn off the TC if you're stuck, b/c then it'll just burn up your brakes and keep detuning ur engine...
Old Dec 8, 2005 | 04:26 PM
Richfiero's Avatar
Richfiero
Traction control uses your brakes to stop the tire from "spinning out" it uses the same system as your anti lock brakes. its just extra software.
Old Dec 8, 2005 | 05:45 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
ORIGINAL: Richfiero
It also pulls timing and reduces fuel.
Old Dec 8, 2005 | 06:18 PM
mustangman02232's Avatar
mustangman02232
in order to "stage" it, turn off TC, leave it in drive or put it in first with O/D off, pull the e-break and go as far down as you can on the break pedal, rev the engine to about 1500 rpm or so then let off the e-break first then the breaks right as that comes down if you have an auto, if you have a stick just rev and dump, the green light is saying that trac is active.
Old Dec 8, 2005 | 06:34 PM
*Blk_96_Stang_GT*'s Avatar
*Blk_96_Stang_GT*
When i was at the track i left Overdrive on, should i have it off for better times??
Old Dec 8, 2005 | 06:36 PM
pj1010's Avatar
pj1010
ORIGINAL: *Blk_96_Stang_GT*
Do you hit 4th gear in the 1/4?
Old Dec 8, 2005 | 10:53 PM
mustangman02232
ORIGINAL: pj1010
yes you should. unless u have gears and a tune
Old Dec 8, 2005 | 10:55 PM
*Blk_96_Stang_GT*
I have 3:73's and i cant remember if i hit 4th gear it was a while ago.
Old Dec 9, 2005 | 12:32 AM
pj1010's Avatar
pj1010
ORIGINAL: mustangman02232
ORIGINAL: pj1010
Well if what he says is true, yes you need O/D on or else your ganna rev out 3rd and quit.
Old Dec 9, 2005 | 01:06 AM
*Blk_96_Stang_GT*
How far does third gear go with normal gears..cause i only hit 90 in 1/4
