TIRE psi
Old Dec 5, 2005 | 03:30 PM
01musgt's Avatar
01musgt
Default TIRE psi
i was wondering if any one can give me tips on what psi the front and rear tires on my 01 mustang should be when i race at the tracks
im looking to drop my E/T
Old Dec 5, 2005 | 03:50 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: TIRE psi
42-45 in the front, and pretty close to tire rating for the rears, maybe drop 5-7 psi only.
if you drop too much pressure in a radial, it will cause the center of the tire to "bow" inwards, and you actually get less traction
getting it WOT is the hard part w/ a stick...have to slip the clutch while keeping the r's up.
just takes practice, or get some sticky tires for the track.
Old Dec 5, 2005 | 04:43 PM
Vash the Stampede's Avatar
Vash the Stampede
i have 40ish PSI in the front. and 20 in the rear. my rear tire is actually a 285. its kinda small for my rear wheels. but i was too cheap to get 315's. max pressure on my tires is 50 or 55.
not sure how much your supposed to flatten the rear.. but i did 20PSI in the rear and the tires look like it still has its form.. doesn't look flat at all.
Old Dec 5, 2005 | 05:34 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
ORIGINAL: Vash the Stampede
If it's not a drag radial or slick, you gain nothing by reducing the tire pressure. You do, however, increase the risk of tire failure.
Old Dec 5, 2005 | 06:25 PM
Tim37's Avatar
Tim37
if you look on the sid wall there will be a max psi usualy around 45psi set your front to that.
on the back drop them down to about 28 psi don't drop your rear below about 26 its not good on a standard radial tire and you won't get any more out of it. thats what i find works best for me
Old Dec 5, 2005 | 07:30 PM
OnyxCobra's Avatar
OnyxCobra
ORIGINAL: MikeHawke
thats what ive always heard too, it also creates uneven tirewear.
Vash- Low profile tires dont always look flat when they have low psi, so sometimes its hard to tell w/ low profile, esp if you have a really stiff sidewall.
Old Dec 5, 2005 | 08:24 PM
MikeHawke's Avatar
MikeHawke
ORIGINAL: OnyxCobra
ORIGINAL: MikeHawke
I have seen it. There are always kids at the track I frequent who are letting the air out of their stock radials and doing huge burnouts with them.
They don't listen. I can't tell you how many times I have seen them pop the bead. Even the ones who manage to get off the line don't realize the effect that having 2 flat rear tires has at 90+ MPH under full throttle.
I'm not saying that Tim37 is incorrect. He is absolutely correct. It does not hurt to drop a few pounds out of the tires. That CAN actually help you a little bit, but keep it reasonable and safe. You really don't want to have the *** end start wandering and hit the wall. It's ugly and usually your insurance won't cover you for accidents at the track.
Old Dec 6, 2005 | 02:54 AM
doobs's Avatar
doobs
Vash,
285's aren't that bad. Their a lot better than 225's and 235's[8D]
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
