auto vs. manual
Old Dec 16, 2005 | 07:09 PM
shane361's Avatar
shane361
Default RE: auto vs. manual
ORIGINAL: nitrous_bob
manual all day long....and even built up and auto is still crappier geared than a manual....so there is room for error.
high hp cars use a 2 -speed cuz there is nothing to them....they can rebuild it evry run in about about 1/2 hour.
plus a powerglide 2-speed is the strongest trans you can buy. thats why they use them....
Not being obnoxious..however I think most people think I am especially on this forum[&:] But...if you take an 04 Cobra that is stock with a manual tranny and you take a 04 Cobra with an auto with the perfect gears and torque converter you think the manual would take the auto?! If that was the case..then why do so many Cobra guys take the standard out for the auto???-Shane
Old Dec 16, 2005 | 07:29 PM
MrFedEx503's Avatar
MrFedEx503
Manuals are the most funa anyways.... its the way a car is ment to be driven... Have total control of what gear you are in.... better MPG,,, but i dunno about at the track, i dont do that track racin
Old Dec 16, 2005 | 07:49 PM
Tim37's Avatar
Tim37
ORIGINAL: waxyourboard
Been gone over and over in the forums...
But on a stock car with any sort of competent driver, the manual will be faster. With the type of power stockers put out, an auto is too lossy to make up for its quick shifts. Same with the programmed auto.
Now build the motor to where you lose traction at the 1-2 shift with a manual, and build the auto to handle your power, and your auto will be faster.
Top fuelies dont even use gears... They have one... Forwards. Clutch slippage gets them down the first half of the track... until the clutch fuses together because of all the heat
+1
on a mild street car a manual will get it done quicker but when you start making real power most poeple go to a auto or a clutchless manual.
Old Dec 16, 2005 | 07:50 PM
shane361's Avatar
shane361
Manuals are more fun I love my Cobra and the fact that I can throw her into any gear at any moment is great. In that aspect the standard is far superior no matter what you do to a auto. But from a dig..I have to say auto after properly equiped-Shane
Old Dec 16, 2005 | 07:52 PM
Tim37's Avatar
Tim37
ORIGINAL: shane361
i agree with you there thats why i went out of my way to find a 5spd car but if i was building a all out track car or a good stout street car i would go with a auto.
Old Dec 16, 2005 | 08:17 PM
93StangLX's Avatar
93StangLX
All the really fast cars are automatic...
Old Dec 16, 2005 | 11:22 PM
waxyourboard's Avatar
waxyourboard
ORIGINAL: 93StangLX
Because they have enough power to shatter the clutch and/or break loose between every gear with a manual
Old Dec 17, 2005 | 01:49 AM
MCFAST's Avatar
MCFAST
ORIGINAL: 03YellowPony
THEORETICALY, the manual is faster than the auto. BUT, look at a dragster..they use either ONE gear or a 2 gear AUTO. With a tuner, an auto can get somewhat closer to a manual. With a stall converter, and a shift kit, it will come closer. With a full manual valve body, it SHOULD do better than a manual. Question..when was the last time you heard of an auto blowing a shift???
Top fuel dragster are NOT auto, thay use one gear with a air control, 8 to 12 disk manual clutch, thay let it slip for the first 300ft to control traction after that it locks up soild.
Old Dec 17, 2005 | 12:37 PM
Tim37's Avatar
Tim37
ORIGINAL: 93StangLX
what about the guys running lenco's
Old Dec 17, 2005 | 04:10 PM
MCFAST's Avatar
MCFAST
ORIGINAL: 93StangLX
NO and NO
