Quick radiator help
Old Dec 17, 2005 | 12:38 AM
ByPopularDemand's Avatar
ByPopularDemand
Default Quick radiator help
Ok my radiator has a bad leak it looks like its coming from the bottom right where the silver and black part meet. anyone know of a quick fix till I get a new one
Old Dec 17, 2005 | 02:36 AM
downwardspiral's Avatar
downwardspiral
Default RE: Quick radiator help
what did they say on mythbusters? did an egg work?
Old Dec 17, 2005 | 01:18 PM
tangtang's Avatar
tangtang
check if it is coming from one of the hoses or if there is actually a crack in the plastic. The hoses are easy and cheap to replace, you can get them at any autozone. A crack in the radiator, well i haven't heared of any quick fixes but I guess if it is "small" enough i would try epoxy.
Old Dec 17, 2005 | 04:17 PM
MAXAir's Avatar
MAXAir
If it's coming from where the black plastic (nylon) tank attaches to the aluminum core, you have a gasket leak. The tank seals on a gasket. You may want to try removing the rad and tightening the 'tabs' that hold the tank on. From experience I have to tell you that there is no real good repair. Also, watch what type of 'stop leak' products you add. They can quickly clog up a heater core too!
Hope this helps!
Old Dec 17, 2005 | 06:09 PM
ByPopularDemand
I looked and it is cracked right where the cooling fan crosses the radiator will some stop leak work
Old Dec 17, 2005 | 11:13 PM
vfast's Avatar
vfast
I ♥ Acer
use bondo..it works and you can paint it black...it will hold for a long time til you buy a 3 core rad
Old Dec 18, 2005 | 03:56 PM
5.0 MPG's Avatar
5.0 MPG
I had a similar problem they sell leak fix at walmart for a couple bucks. The one I used is silver/grey in a clear bottle. Worked great for me.
Old Dec 18, 2005 | 03:59 PM
5.0 MPG's Avatar
5.0 MPG
Also here is a great deal on a used one. I almost bought it just to re-sell..
http://cgi.ebay.com/ebaymotors/Musta...spagenameZWDVW
Old Dec 18, 2005 | 04:19 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: 5.0 MPG
Wouldn't work. He's got a 3.8
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
