Octane
Old Dec 18, 2005 | 08:07 PM
ByPopularDemand's Avatar
ByPopularDemand
Default Octane
How long does it take gas to lose its octane.
Old Dec 18, 2005 | 08:27 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Octane
If it's in a sealed drum a long long time. We gas that was over a year old at the last NMRA reace that we did and it passed tech just fine. But if it's just in the ground or in your tank I bet a few months is all it lasts at most.
Old Dec 18, 2005 | 09:00 PM
Chopper's Avatar
Chopper
Default RE: Octane
After thirty days in a gas tank I would be suspicious.A sealed container should be able to keep it good forever.
Old Dec 18, 2005 | 10:02 PM
ByPopularDemand
Default RE: Octane
My car has sat for two months and it starts realy rough. The gas in the tank is probably done huh
Old Dec 19, 2005 | 10:48 AM
Chopper's Avatar
Chopper
Default RE: Octane
ORIGINAL: ByPopularDemand
You can save the gas you have in the tank by filling up with new,fresh gas.My bikes go through this sometimes when the weather is bad and topping off the tank helps a lot.It doesn't take much.
Old Dec 19, 2005 | 04:38 PM
Birdieman4's Avatar
Birdieman4
Default RE: Octane
As JD said, it will keep for some time if it is sealed. One thing you have to watch out for is condensation while gas is being stored. If the container isn't full, temperature changes can cause condensation inside the container, and dilute down the gas. Keep containers full, while in storage, especially in areas prone to temp change.
msavoia23
12
Jul 7, 2018 12:08 PM
Big Al's 03
Sep 15, 2015 09:05 AM
MasterLanMan
Sep 13, 2015 08:21 PM
Sandmanbjj
Aug 21, 2015 12:38 PM
dragman72
Aug 9, 2015 12:54 AM
