sorry not bout a stang but i need help
i also have a 91 town car i have tried to get the awnser for this questin in othe fourums but no luck does anyone know how to change the cable that goes fron the tranny to the colum by the way its an experimental 4.6 that was factory in ths car ad i cannot figure it out ne feed back plaes help me thank you guys i hope some one has an ideal what or how i can fix this
RE: sorry not bout a stang but i need help
Thats probably the shift cable.You should start at the steering column and remove that end first.Then feed it down through the firewall and remove it from the transmission.Installation would be to reverse the removal procedure.The steering column should be dropped down to get as much room to work as you can.This is all just a guess but thats all I have.
