Tips on replacing inner tie rods
Old Dec 28, 2005 | 07:41 PM
Crystal's Avatar
Crystal
Default Tips on replacing inner tie rods
I went to get my front end aligned and it was refused until I get the left inner tie rod replaced because there is too much play on the tire. Got any tips before I start? I do have the Haynes manual but sometimes it's good to receive additional advice from others to avoid some frustration.
Thanks guys!
Old Dec 28, 2005 | 08:28 PM
Tim37's Avatar
Tim37
Default RE: Tips on replacing inner tie rods
get the car off the ground as hight as possible and you will need a special tool to get teh innter tie rod out. first pope the wheel off for more room then loseen the jam nut is on the inner tie rod then unscrew the tie rod out of the outer tie rod next pop the rubber boot off. now the inner tie rod tool comes in to play use it with the apropirat fitting to unscrew thn inner tie rod. then use lock tite (a lot of times a small package will come with the part) and put the new tie rod in. you will need a zip tie to replace to boot on the rack. when you scew the inner tie rod back in to the outter tie rod try to get it some what close to where it was it will make it easier to alighn.
Old Dec 29, 2005 | 05:36 PM
Crystal's Avatar
Crystal
ORIGINAL: Tim37
Job's done. LOL!! Dad didn't bother to get the right tool and oops, something slipped and broke the outter one. LOL!! That'll be done too. WE ARE JUST HAVING TOO MUCH FUN!!!
Old Dec 30, 2005 | 01:22 PM
Tim37's Avatar
Tim37
Be sure to go ahead and get an alighment any time you do front end work.
outer tie rod ends much easyer it can be done in about ten min. just unbolt use a ball joint separator fork then scew it off the inner and replace.
Old Dec 30, 2005 | 02:59 PM
Crystal's Avatar
Crystal
That job's done too. Car is getting the front end alignment as we speak.
Old Dec 30, 2005 | 04:35 PM
Tim37's Avatar
Tim37
cool i hope you get all the gremlins worked out of it soon
5.0muscle
Jan 11, 2016 01:17 PM
MusicCity615
Sep 12, 2015 07:05 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
RWHEELS
Sep 5, 2015 03:42 PM
kawiguy827
Sep 1, 2015 07:09 PM
