Problem
Old Dec 30, 2005 | 05:41 AM
1BAD3V's Avatar
1BAD3V
Default Problem
I have a big problem. I recently bought and installed a Mac o/r h-pipe. I went out and bought some new bolts and nuts to connect it to the catback. I didnt really like the ones they gave me so I went and got some more. Anyways, me and my friend both tightened them as tight as we could with a ratchet and wrench. But for some reason they keep coming loose and I've done lost like 4 bolts. I think the catback is not staying in place and therefore is weighing down and the nuts and bolts cant hold up because of the pressure. I've done been under the car for the past 3 days tightening the nuts and I've had to go and buy new ones because I lost the other ones. Is there anyway to keep this from happening? I bought a bolt that is thin thread on one end and like the bolts I got with the h-pipe, so I can still use the nuts that also came with the h-pipe. This is really pissing me off, so can someone please help.
Thanks
Old Dec 30, 2005 | 06:08 AM
OnyxCobra's Avatar
OnyxCobra
Default RE: Problem
maybe try using a lock washer or something? high temp locktite? are you sure the treads are a perfect match?
Old Dec 30, 2005 | 06:26 AM
1BAD3V's Avatar
1BAD3V
Default RE: Problem
Yes they are a perfect match. Me and the guy at Autozone went through and tested all of them. It screws in just fine and it looks good. But then after driving for like a day or so they come loose and fall on the ground and I got to go buy new ones. Its actually kinda stressing me out. I basically dont wanna drive the car unless I get this finished, but Its my only car so I have to drive it. I drive kinda slow and worry about the pipe falling, which I dont think is gonna happen because its bolted real good on the manifold (very secure). Anyways I dont know what the hell the problem is, and another thing is since I dont have cats the SES light is on, but I have mil eliminators, do those take awhile to kick in and make the light go off?
Thanks
Old Dec 30, 2005 | 09:42 AM
1BAD3V's Avatar
1BAD3V
Default RE: Problem
Is this not the right section to be posting this? If not then where should I post it so I can get some responses so I can get it fixed?
Old Dec 30, 2005 | 03:09 PM
sandcracker21's Avatar
sandcracker21
Default RE: Problem
you could try pipes/boost/juice section as well
as far as the engine light, try disconecting the battery for 20 min and then reconecting.....
wait about 10 days, if the light doesnt come back on, then you fixed it!
but you havta get that light off, the engine will start acting funny if it doesnt know whats goin on down there
do you have a handheld tuner?
Old Dec 30, 2005 | 04:22 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
Default RE: Problem
nuts come off. Exhaust vibrates and it heats and cools so the metal expands and contracts. That's why you use lock washers and and impact gun to put them on. High temp locktite is good.
I have been known to tack weld them.
Old Dec 30, 2005 | 10:31 PM
1BAD3V's Avatar
1BAD3V
Default RE: Problem
Wouldnt putting locktite on them make it a pain in the *** to undo them again? I'm gonna be installing SLP LM1's and I dont wanna deal with the locktite. Hopefully just the bolts will do until I get the SLP. Couldnt I get bolts that are longer than the ones they gave me?
Thanks
Old Dec 31, 2005 | 08:13 AM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: Problem
ORIGINAL: 01SilverGT
Wouldnt putting locktite on them make it a pain in the *** to undo them again? Thanks
Well if the bolts are backing out constantly, this doesn't sound like such a big problem now does it? LOL
Get some lock washers, use some loctite and be done with it. You don't need to load a ton of loctite on there either, just put enough on to cover 2-3 threads.
Old Dec 31, 2005 | 08:28 AM
1BAD3V's Avatar
1BAD3V
Default RE: Problem
Then what do I do about the loctite when i wanna switch to SLP?
Old Dec 31, 2005 | 01:34 PM
marx91's Avatar
marx91
Default RE: Problem
you can get breakable locktite, that and a jam nut will take care of it
as in tighten down your first nut and lock washer then tighten a second nut against
the first
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
