REAR END question PLEASE HELP!
Old Jan 8, 2006 | 08:37 PM
mus96tang's Avatar
mus96tang
Default REAR END question PLEASE HELP!
Hey guys I'm sorry If I repost this question but I really need some help i'm getting ready to buy a POSI unit for my 96 gt with a 5 speed i've had my ring and pinion changed and all the bearings and seals and still after my car is driven for 10+ miles I get a Vibration when I turn and some clikcing sounds from the rear end of the car never when its cold though what do i DO>>????
Old Jan 8, 2006 | 08:54 PM
Birdieman4's Avatar
Birdieman4
Default RE: REAR END question PLEASE HELP!
First thing you should do is check your differetial level, and make sure it's not leaking, or low (or out). Clicking noises are never good. You could have a bearing issue, quite possibly. I would have someone experienced take a look at it.
Old Jan 8, 2006 | 08:56 PM
mus96tang's Avatar
mus96tang
All the bearings are new just had the master bearing kit intalled with the ring and pinion the sounds were there b4 and after fluid is fine
Old Jan 9, 2006 | 02:58 AM
Birdieman4's Avatar
Birdieman4
It may just need to be re-shimmed.
Old Jan 9, 2006 | 03:13 AM
mus96tang's Avatar
mus96tang
Re- Shimmed but it was doing it b4 the gear work was done
Old Jan 9, 2006 | 01:20 PM
Tim37's Avatar
Tim37
could be the u joints in the drive shaft.
Old Jan 9, 2006 | 03:23 PM
Birdieman4's Avatar
Birdieman4
...And you know for sure that all the bearings are fine? Have you gotten a 2cnd opinion?
GimpyHSHS
Aug 29, 2015 06:30 PM
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
ding56
Aug 14, 2015 02:40 AM
92 5.0stang
Aug 13, 2015 06:46 AM
