Car Wont Start. HELP
Old Jan 13, 2006 | 06:02 AM
KillSwitchNY's Avatar
KillSwitchNY
Default Car Wont Start. HELP
hi i have an 88 mustang gt.
i had a stock fuel pump in the car that was dying out so whenever i would make right turns (only) the car would drop fuel pressure from 43psi to 0 and i would have to restart while driving.
replaced the fuel pump with walbro 255lph pump and now the car wont stall out but will drop pressure from 43 to about 25-30 then come back again when i get straight. this happens when i have 1/2 tank or less.
i have a fuel pressure guage in my car in case your wondering where i got the numbers.
today i took a right turn and the car died out. i know i had low gas (but my fuel guage is innacurate even though i replaced the sending unit)<can you fix that?
i left the car for a few hours and the pressure had built itself back up and i was able to run for about 30 seconds before running out of gas again... i still hear the pump spool up when ignition on but not as loud as before
i filled with gas and still nothing . spent 6 hours tonite in the middle of the road trying to get it started. i disconnected the fuel press guage to releive any air caught in there and there was no pressure at all. finally got a pull home.
sorry about the story just wanted you to know the details so hopefully you can help me..
Old Jan 13, 2006 | 11:14 AM
Chopper's Avatar
Chopper
Default RE: Car Wont Start. HELP
I remember your last post about this problem.WOW,there has to be an electrical gremlin involved.The only thing I can think of is to hook up a pressure guage.Raise the car as high as you can,a lift would be handy,and start moving wires underneath the car.Move hard parts also because they could be shifting under the G-forces and contacting a wire and causing an open circuit.
Another approach would be to run a dedicated circuit to the fuel pump and see if the problem dissapears.Try running wires directly from the battery with a switch inside the car to isolate the cars electrical system.
jpplaw
Mar 19, 2025 08:53 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
'stangdude
Aug 12, 2015 01:27 PM
