Clutch wear
Old Jan 13, 2006 | 03:00 PM
stradmaster's Avatar
stradmaster
Default Clutch wear
I need someone to help me understand how this works. As the clutch wears, what happens to the point in pedal travel where it begins to engage? Does it get progressively higher in the pedal travel (mine seems high, and higher than it used to be) or do I have some sort of hydraulic problem?
Any comments would be appreciated!
Old Jan 13, 2006 | 09:32 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: Clutch wear
the clutch is not hydraulic.
as it wears it will engage furthur and further from the floor.
also might not be fully engaging when out completely, could be why your wearing fast.
if it's stock, just pull up on the clutch pedal hard.
Old Jan 14, 2006 | 01:03 AM
stradmaster
So if it's cable actuated, is it adjustable or self adjusting? BTW it does not show any signs of slippage in any gear or revs.
Old Jan 14, 2006 | 03:06 AM
ShadowDrake's Avatar
ShadowDrake
You adjust it by pulling up on the pedal. It'll click a few times if it is being tightened up.
Old Jan 14, 2006 | 04:02 PM
stradmaster
Thanks. I will try adjusting it.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
