351 windsor help
Old Jan 16, 2006 | 05:13 PM
HolidayGT's Avatar
HolidayGT
Default 351 windsor help
i have 1996 gt 2valve gt i want to build the motor but it is a bit of a bastard of a motor to modify. so my quetion to you guys is should i build the motor that is in it or build another one i would like to have about 400hp at the wheels all motor not sure on witch route to go im am kind of new to the whole mustang modification thing i know ther a lot of opptions out there but not a lot for the 96 gt 2 valve motor so i wolud like some input from the pros. thanks alot for your time.
Old Jan 16, 2006 | 05:22 PM
Tim37's Avatar
Tim37
Default RE: 351 windsor help
well first off ditch the heads and intake and go for the pi heads intake you will pick up a lot of hp there.
as far as a windsor vs. rameo (what ever it is) i think the windsor block is suposed to be a little better it has larger oiling passages.
but if you stick with the stock pistons in that 96 they aren't real strong but you will have around 10:1 compression with pi heads.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Mustangs of Illinois
Aug 22, 2015 10:00 PM
89blueslug
Aug 10, 2015 07:20 AM
