Thowout bearing noisy
Old Jan 17, 2006 | 01:06 PM
tsherer's Avatar
tsherer
Default Thowout bearing noisy
1994 GT, not sure if original clutch or not. It seems to shift ok and is not slipping. Do I need a new clutch or can this be adjusted. When I press the clutch a small amount, the noise goes away. I would appreciate any feed back. Also, where is the best place online to buy a "King Cobra Clutch". I have read there are fakes out there.
Old Jan 17, 2006 | 01:16 PM
Djs94stang's Avatar
Djs94stang
Default RE: Thowout bearing noisy
If it is a chirping noise or sounds like cyclical squeaking...it is a common problem in the clutch design. Resting your foot slightly on the pedal will get rid of it. I've tried new components and switching from an alum to steel bearing retainer and the problem seems to come back. I posted this long ago and found that it is a common problem even on the later model 4.6's ...I have a 94, 5.0.
Old Jan 17, 2006 | 02:38 PM
Birdieman4's Avatar
Birdieman4
It is your throwout bearing. There is no way to adjust it, it will do it 'til you get a new clutch. It will probably get worse. This often times comes pre-maturely when you rest your foot on the clutch pedal during normal driving.
Old Jan 17, 2006 | 02:58 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
what if youve never ridden the clutch? can it happen just from normal wear, or hard wear? maybe missing a shift once and pining it off the rev limiter. .lol.. i mean, not that ive.. ever.. had that happen...
i was just thinking about it today though, does it cause any damage if its doing what it does,(spinning all the time now)? or waht?
anyoen with any imput, i need some reassurance i dont need to replae anything..
Old Jan 17, 2006 | 03:06 PM
mustang_montana's Avatar
mustang_montana
mine started going around 110k miles, not sure if it was original but it started with cold weather, and it was only on and off. eventually it got worse but by then the engine swap and clutch was done so problem solved. ive heard that if you leave your foot on the clutch at lights and stops that itll increase the wear of the throw out bearing (well that makes sense at least) may be for the older manuals though.
Old Jan 17, 2006 | 04:17 PM
Dan04COBRA's Avatar
Dan04COBRA
Ford's seem to have non-stop TOB issues.
Old Jan 17, 2006 | 04:28 PM
tsherer's Avatar
tsherer
Thanks for all of the input. I want to spend around 200.00 for a clutch kit. What is the most decent one and where online can I buy one.
Old Jan 17, 2006 | 06:55 PM
Birdieman4's Avatar
Birdieman4
Yes, it can go out from normal wear and tear. But usually (if the clutch is newer) there is some reason why. One other way this can happen prematurely is if you have a manual cable in there, and you don't adjust the cable for clutch wear and pedal travel.
6bangr
Feb 15, 2016 07:40 AM
KingRando
Oct 2, 2015 08:06 AM
Offendant
Sep 23, 2015 07:21 PM
ccdguy
Sep 19, 2015 05:20 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
