Xeon Light
Old Jan 17, 2006 | 06:24 PM
JB072's Avatar
JB072
Default Xeon Light
I have a 96 GT and i want to install xeon lights can i just buy the xeon light bulbs and put them in or do i have to get a whole kit and change the inside of the lights?
Thanks
Old Jan 17, 2006 | 06:28 PM
ekthrilla's Avatar
ekthrilla
Default RE: Xeon Light
xeon does sell the replacement bulbs. just go to your local car parts store and they should have them there. ask them the part number and you are set.
Old Jan 17, 2006 | 07:06 PM
JB072's Avatar
JB072
Hey
Ok but i was talking to my freind and he said that you have would have to buy somthing like this http://www.xtralights.com/hidkit_popup/HIDkit_popup.htm or can i just go get bulbs anf switch them with the halogen ones
Thanks
Old Jan 17, 2006 | 09:44 PM
nelson95's Avatar
nelson95
just buy the kit u can buy it a auto zone or a place like that and run it off a switch
Old Jan 18, 2006 | 01:18 PM
The Great Cornholio's Avatar
The Great Cornholio
I ♥ Acer
ORIGINAL: JB072
Hey
Thanks
That is a true HID conversion kit. Go with something like that or do nothing at all. So-called "Xenon Look Bulbs" are only lookalikes that can draw up to 100 watts.....not good for your stock headlight wiring harnesses, connectors, or switch.
Old Jan 18, 2006 | 02:06 PM
closer9's Avatar
closer9
I have run high wattage bulbs in several vehicles, but I use a heavy duty harness run directly off the battery. I prefer the harness regardless, especially in older vehicles...
The lights with the high wattage and HD harness is much whiter than stock. Not as bright as HID, but for the money much better than stock...
Old Jan 18, 2006 | 02:29 PM
The Great Cornholio
I ♥ Acer
Right, a heavy duty harness run directly from the battery makes high-wattage bulbs a usable option. Better quality HID conversion kits use the same approach. They power the ballasts directly from the battery via relays; the stock headlight switch and wiring is only used to open and close two relays in the kit harness
Old Jan 18, 2006 | 03:19 PM
closer9's Avatar
closer9
Yep...
I had this same setup in my '84 300ZX. I was only getting 10.5v to the headlights while the car was running. I just used the HD harness with the stock bulbs, and it was like night and day, literally (2 or 3 volts makes a huge difference in headlight output). I couldn't drive the car at night before. I then upgraded the housings and added high wattage bulbs, and it was even better... As mentioned above, don't run the high wattage bulbs on stock wiring, but if you want to upgrade I recommend using the HD harness and high watt bulb verses Silverstars... or HID... which I really want for the Stang...
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
