Which is the right Regulator
Old Jan 20, 2006 | 07:56 AM
KillSwitchNY's Avatar
KillSwitchNY
Default Which is the right Regulator
seems that the instrument voltage regulator aka slosh module is obsolete, so ive been looking on ebay for one because my fuel guage goes berzerk all the time...
anyone know which one if either of these 2 will fit my 88 GT?
they both say they will fit like 1965- 86 and what not. please help
[IMG]local://upfiles/21720/9D24BA1FCE3C42F89C1D60CA6A7E42F3.jpg[/IMG]
[IMG]local://upfiles/21720/688A7C7C56D542E39FD59C84737B63F4.jpg[/IMG]
Old Jan 20, 2006 | 08:57 AM
stanglx2002's Avatar
stanglx2002
Default RE: Which is the right Regulator
if your fuel gauge is going crazy then your sending unit is messed up and needs to be replaced get new new unit and drop the tank and put it in
Old Jan 20, 2006 | 09:25 AM
Joel5.0's Avatar
Joel5.0
ORIGINAL: KillSwitchNY
The slosh module doesn't interfere with the alternator's regulation. If you have a problem with the fuel gauge, it's recommended to do a resistors test to figure out if it's a problem with the sender or the slosh module. GL
Old Jan 20, 2006 | 10:38 AM
KillSwitchNY
no, i already put a new sending unit. its got to be the regulator.
the sending unit helped a little bit by calming the needle down a bit.
Old Jan 22, 2006 | 10:39 PM
Joel5.0's Avatar
Joel5.0
The anti-slosh module is located behind the instrument panel module, it's either a bolt-on type like:
......or a plug-in type (sorry don't have a pic). You should also check that your problem is not caused by a bad body-to-engine ground strap or connection. The fuel indicator will move when a load (head lights, stop lights, wiper motor, A/C...) is present, if the ground is poor. GL
Old Jan 23, 2006 | 02:31 AM
KillSwitchNY
anyone know if the slosh module is any different from the 8 and 4 cyl? theres an 88 4 cyl notch in a junk yard with the cluster that i want. would like to know if all the cars had the same fuel mesurement system
Old Jan 23, 2006 | 10:00 AM
Joel5.0's Avatar
Joel5.0
You can use the module from the 4 cyl., instrument panel and fuel sending units are the same. GL
mrtrodonet
Sep 19, 2020 03:12 PM
LiquidDrink
Sep 29, 2015 10:06 AM
Meystang
Sep 25, 2015 04:05 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
