Electrical help needed oh so badly
Old Jan 22, 2006 | 03:47 AM
Milky's Avatar
Milky
Default Electrical help needed oh so badly
It seems as though every once in a while my left headlight will go out as well as the left corner light. The bulbs are good because the lights are only out some ofthe time. Also, the high beams indicator on the dash goes on and off at will and doesn't seem to have any association with the headlights being on or off. Does anybody have any idea what this might be?
I just noticed some lights work when the tree on the left is moved one way and other lights work when the tree is shifted the other way. Does it sound like I'll be needing to re-wire something in the dash or at the lights or what?
Old Jan 22, 2006 | 04:07 AM
posnick's Avatar
posnick
Default RE: Electrical help needed oh so badly
only wat to find out for sure is to follow the electrical from the problem allthe way back. could be a break in the wire. good luck. i hate electrical problems
Old Jan 22, 2006 | 11:14 AM
Lee Willis's Avatar
Lee Willis
It is very likely to be a bad ground, that would be about the only common wire to the two lights you are having problems with, so I would start there. Check to see if the ground wire (return path wire which often just goes to the body or somewhere close), is loose, or the contact point corroded, etc.
Old Jan 23, 2006 | 04:14 AM
Milky's Avatar
Milky
Would the ground wire be coming right off the lights and onto the chassis somewhere?
Old Jan 23, 2006 | 05:41 AM
opie1's Avatar
opie1
no probably runs through the original wiring harness to a common ground
djbigskrilla
Sep 20, 2022 01:04 AM
mweiland
Aug 16, 2015 10:59 AM
drumhedd2005
Aug 13, 2015 09:59 AM
defarmer
Aug 13, 2015 06:40 AM
89blueslug
Aug 10, 2015 07:20 AM
