ignition or something..
Old Jan 26, 2006 | 02:48 PM
83hatchback's Avatar
83hatchback
Default ignition or something..
lol i just tryed to start my car and it wouldnt start at all not even a noise.... i think it has somthing to do with my ignition or somthing because if i open the hood and put a screw driver to the left side on 2 bolts it starts right up... LOL is that ghetto or supposto be like that? and i tryed starting the car wit the keys before and it started but now it wont.. any sugestions?
Old Jan 26, 2006 | 04:51 PM
wildcobrar's Avatar
wildcobrar
Default RE: ignition or something..
there is a plastic ignition switch bolted on the top side of the steering column. They are known for going bad, or you may have a bad solenoid. There is a red wire with a blue tracer on the solenoid. unhook it and run a jumper to the terminal from the battery positive side. If it tunrs over, the solenoid is good. Take a test light and see if this red/blue wire has power when the key is held forward in the start position. If not check the ignition switch.
Old Jan 26, 2006 | 07:51 PM
marx91's Avatar
marx91
its your solenoid
bradleyb
Nov 27, 2015 07:50 PM
piotrek53
Oct 13, 2015 06:54 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
jessicarabbit
Sep 25, 2015 12:41 PM
Wombatnation
Sep 13, 2015 09:16 PM
