atf mercon in a 5speed?
Old Jan 27, 2006 | 10:23 AM
83hatchback's Avatar
83hatchback
Default atf mercon in a 5speed?
someone posted:
Yes the fill and fluid level check is the plug on the side of the tranny. I don't mean to correct, but if memory serves me the T-5 takes ATF (Mercon). The tranny should have fluid up to the bottom of the fill plug hole.
i did find atf fluid in the trunk of the car.... should i fill it up with that? it says its for automatic transmisions... i got a 5 speed
Old Jan 27, 2006 | 12:25 PM
Tim37's Avatar
Tim37
Default RE: atf mercon in a 5speed?
check your t5 some of them used maual gear oil some used atf. so be sure the easiest way is to pull your fill plug stick your finger in and see if its atf or grease.
Old Jan 27, 2006 | 09:06 PM
uedlose's Avatar
uedlose
all t-5 use atf.but some people put light weight motor oil in them also.DO NOT put gear oil in it.
Old Jan 28, 2006 | 07:57 AM
03zx2's Avatar
03zx2
would it be all right to put gm syncromesh in a 3650 tranny?
Old Jan 28, 2006 | 10:48 AM
uedlose's Avatar
uedlose
yes the syncromesh sould be ok also.
foxdude
Sep 24, 2015 08:45 PM
algregory
Sep 6, 2015 05:52 PM
inyadreems
Aug 21, 2015 09:10 AM
Greyshot
Aug 15, 2015 03:32 AM
04mustang
Jun 17, 2004 02:16 AM
