performance chip
Old Jan 28, 2006 | 03:14 AM
Scooterman's Avatar
Scooterman
Default performance chip
would a performance chip for a modded 87 5.0 be good to purchase, if so, what kinda increases would i get, an estimate really b/c im thinkin bout chippin' my car
Old Jan 28, 2006 | 03:17 AM
SpecterGT260's Avatar
SpecterGT260
Default RE: performance chip
I would go with a hand held tuner for anything that is modded. You can always order out custom tunes by telling the company your mods (i think superchips might do this) but they are usually right about worthless. With a handheld you can experiment some.
Old Jan 28, 2006 | 05:59 AM
HC_CrAzYHoRsE's Avatar
HC_CrAzYHoRsE
i installed a diablosport on my ZX3 and felt absolutely nothing. the company said about a 10% hp and tq increase ....i think i would've felt an extra 14hp/14lbstq but no ...absolutely nothing. it did remove my speed limiter though, wich was worth every cent.
Old Jan 28, 2006 | 05:09 PM
hunter9s's Avatar
hunter9s
I installed a Diablo Predetor sport on my 02 mustang GT and it really made a difference. My car flat out runs alot faster now than before. Now I think alot of it has to do with the other mods I had done. I hear such a mixed response and I have to attrubute it to the mods you already have. I will give you a list if what I have done. Cold air intake /w K & W air filter, 2 contriverisal parts..Bosch titanium 4 prong spark plugs, turbonator, 3:73 rear, steeda tri axe shifter, new Goodyears all the way around, Dynomax exhaust system, long tube headers. I think thats it. I can't expalain it but it really helped my car alot. Going thru the gears it really puts you in the seat. The cold air intake I did modify ( I'm an x 25 yr plumber who is disabled ). I modified it to shove some air up the intake, so I don't know if the extra air is telling the new computer program to add more fuel to avoid a over lean condition or not. I only have 10 or 15 miles on this set up. The weather in PA is not coperating. I'm gonna run this set up for awhile and see what happens. Oh by the way if you are runing a chip on your incoming air temp, unhook it to run the Predetor. Thats my 2 cents
steve
Old Jan 28, 2006 | 05:54 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: hunter9s
steve
They don't make a tuner for the 87's. But yes, a chip will give you some good improvement. HyperTech or SCT should have them for you.
Old Jan 29, 2006 | 05:47 AM
P.S.I.cho's Avatar
P.S.I.cho
the diablo delta chip is in my car, and what they do is when u buy the chip from a speed shop they give u the most basic tune, wich is why most people think the chip didnt do anything, since u have mods what u need to do is go throw it on a dyno and with the dyno sheet the tuner should be able to tune the chip to what your car put out, this is where the 10-15% horse power increase comes from, also the chip responds better to certain mods, the main mods would be cam, crahk, supercharger, exhaust on most chips.
jwog666
Dec 27, 2021 08:09 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
